AutoCAD Electrical General
Active Contributor
stefan.stamate
Message 1 of 9 (446 Views)
Accepted Solution
2013 crashes: subfolders created & opened in 2012
446 Views, 8 Replies
08-16-2012 02:30 PM
In our office we have Autocad Electrical 2013 on one of the computers and 2012 on the other two. After creating a project in 2013 and adding subfolders to it we opened it up in 2012 to make some edits. After comparing the old wdp file (2013) with the new one (2012) we discovered that 2012 converted the subfolders definition (=====SUB=) to a description definition (===SUB=) and inserted it in the DESC1 line for each drawing. When trying to open it back in 2013 it caused the Autocad to crash with a "Fatal Error" several times. When it worked we could see no subfolders in the project manager and we lost the DESC3 field. Also when trying to re-create the folders it added the new lines in the wdp file (=====SUB=) but kept the old ones as well (===SUB=). This seems to be a bug and I am not sure if it addressed by any of the service packs. Did anybody else encountere this issue? I have attached the error message we got.
Thanks for your help!
Stefan
*Expert Elite*
Message 2 of 9 (418 Views)
Re: 2013 crashes: subfolders created & opened in 2012
08-16-2012 08:54 PM in reply to: stefan.stamate
Only version 2013 supports the virtual subfolders.  Version 2012 will be looking for a description line in the position of the .wdp file where the new subfolder assignment is stored.  You should not assign subfolders if you are going to be using other versions besides 2013.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Active Contributor
stefan.stamate
Message 3 of 9 (375 Views)
08-21-2012 07:02 AM in reply to: dougmcalexander
Thanks for the update!
It would be nice if Autodesk maintained the backward compatibility for at least the last 1-2 versions...
*Expert Elite*
Message 4 of 9 (370 Views)
08-21-2012 08:04 AM in reply to: stefan.stamate
The software can save the file format for compatibility with older versions but features introduced by a new release may not be compatibile with an older version. For example, the core code of 2011 and 2012 would have to be rewritten in order for those versions to interpret the new .wdp format. This is simply not done in the software industry. Microsoft did not go back and update the code of Access 2003 so that it could read version 2007 databases. I experienced this personally. I had to upgrade my databases such that they were no longer compatible with the older versions of Access.
Doug McAlexander
Active Contributor
stefan.stamate
Message 5 of 9 (368 Views)
08-21-2012 08:11 AM in reply to: dougmcalexander
I understand the chellenges when dealing with a database in Autocad but was it considered by Autodesk for instance to use a different identifier/symbol for subfolders in the wdp file than the equal sign which was already used for section/subsection/description lines in previous versions?
*Expert Elite*
Message 6 of 9 (366 Views)
08-21-2012 08:19 AM in reply to: stefan.stamate
I don't think it has so much to do with the equal sign as with the position in the .wdp file. But there is more to it than that. 2012 would not know what to do with such information. It doesn't know about applying project properties to drawings in a subfolder. It doesn't know about drag and drop, etc.
Doug McAlexander
Active Contributor
stefan.stamate
Message 7 of 9 (364 Views)
08-21-2012 08:23 AM in reply to: dougmcalexander
OK, thank you!
*Expert Elite*
Message 8 of 9 (361 Views)
08-21-2012 08:30 AM in reply to: stefan.stamate
If you get a subscription from Autodesk you can keep all of your software up to date so all designers can access and take advantage of all project data in the same fashion.
Doug McAlexander
Active Contributor
stefan.stamate
Message 9 of 9 (357 Views)
08-21-2012 08:42 AM in reply to: dougmcalexander
We have a subscription, 2 seats are client style and 3 are network style. Unfortunatelly the upgrade was not done in the same time for all the licences and we ended up with this problem. Even now the AE 2013 network licenced is reporting the same error or fatal errors when trying to do normal stuff. It seems like the incompatibility between 2012 and 2013 regarding the folders crashed 2013 so badly...I am not sure how we can get rid of these errors at this point. Hopefully Autodesk takes note of it and does a service pack...
You are not logged in.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
