<sgsawdy> wrote in messageStill
href="news:6139138@discussion.autodesk.com">news:6139138@discussion.autodesk.com...
having a problem with this, is anyone else? Thanks.
<sgsawdy> wrote in messageBelow
href="news:6140598@discussion.autodesk.com">news:6140598@discussion.autodesk.com...
is the command line trace. I get no error messages, just don't get values
placed in the attributes unless I do it using attedit or double clicking on
the block and changing them there. Hope this gives you what you need to help
me out. Scott Command: IN:wd_psymed Edit Panel Layout Component Select
component: IN:wd_sed_is_it_schem_or_pnl OUT:wd_sed_is_it_schem_or_pnl=9
IN:wd_ped_pnl_comp(PIO617-1513 1 1 P_TAG1)
IN:wd_psym_get_pnlcomp_attr IN/OUT:wd_1_get_pnlval FPT =
IN/OUT:wd_1_get_attr_val h=42B0 nam=FPT = nilnil(PIO617-1513 1 1 P_TAG1
) IN:wd_psym_get_psyma_ratinglst
IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING1 = IN/OUT:wd_1_get_attr_val h=42B0
nam=RATING2 = IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING3 = nil
IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING4 = nil IN/OUT:wd_1_get_attr_val
h=42B0 nam=RATING5 = nil IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING6 = nil
IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING7 = nil IN/OUT:wd_1_get_attr_val
h=42B0 nam=RATING8 = nil IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING9 = nil
IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING10 = nil IN/OUT:wd_1_get_attr_val
h=42B0 nam=RATING11 = nil IN/OUT:wd_1_get_attr_val h=42B0 nam=RATING12 = nil
OUT:wd_psyma_get_psym_ratinglst IN/OUT:wd_1_get_pnlval DESC1 =
IN/OUT:wd_1_get_attr_val h=42B0 nam=DESC1 = RACK 2RACK 2
IN/OUT:wd_1_get_pnlval DESC2 = IN/OUT:wd_1_get_attr_val h=42B0 nam=DESC2 =
SLOT 2SLOT 2 IN/OUT:wd_1_get_pnlval DESC3 = IN/OUT:wd_1_get_attr_val h=42B0
nam=DESC3 = DIGITAL INPUTDIGITAL INPUT IN/OUT:wd_1_get_pnlval P_ITEM =
IN/OUT:wd_1_get_attr_val h=42B0 nam=P_ITEM = IN/OUT:wd_1_get_pnlval INST =
IN/OUT:wd_1_get_attr_val h=42B0 nam=INST = IN/OUT:wd_1_get_pnlval LOC =
IN/OUT:wd_1_get_attr_val h=42B0 nam=LOC = IN/OUT:wd_1_get_pnlval MFG =
IN/OUT:wd_1_get_attr_val h=42B0 nam=MFG = ABAB IN/OUT:wd_1_get_pnlval CAT =
IN/OUT:wd_1_get_attr_val h=42B0 nam=CAT = 1734-TB31734-TB3
IN/OUT:wd_1_get_pnlval ASSYCODE = IN/OUT:wd_1_get_attr_val h=42B0 nam=ASSYCODE
= IN/OUT:wd_1_get_pnlval CNT = IN/OUT:wd_1_get_attr_val h=42B0 nam=CNT =
IN/OUT:wd_1_get_pnlval UM = IN/OUT:wd_1_get_attr_val h=42B0 nam=UM =
IN/OUT:wd_1_get_pnlval WDBLKNAM = IN/OUT:wd_1_get_attr_val h=42B0 nam=WDBLKNAM
= PLCIOPLCIO IN/OUT:wd_1_get_pnlval MOUNT = IN/OUT:wd_1_get_attr_val h=42B0
nam=MOUNT = IN/OUT:wd_1_get_pnlval GROUPWITH = IN/OUT:wd_1_get_attr_val h=42B0
nam=GROUPWITH = IN:wd_psym_get_psyma_poslst OUT:wd_psyma_get_psym_poslst
OUT:wd_psym_get_pnlcomp_attr IN:wd_ped_doedit en=
eflag=nil (PIO617-1513 AB 1734-TB3 RACK 2 SLOT 2 DIGITAL INPUT PLCIO ( ) x)
IN/OUT:wd_1_get_pnlval FPT = IN/OUT:wd_1_get_attr_val h=42B0 nam=FPT = nilnil
IN/OUT:wd_1_get_pnlval NP = IN/OUT:wd_1_get_attr_val h=42B0 nam=NP = nilnil
IN:wd_bomr_figure_wdblknam IN/OUT:wd_1_get_pnlval WDBLKNAM =
IN/OUT:wd_1_get_attr_val h=42B0 nam=WDBLKNAM = PLCIOPLCIO
OUT:wd_bomr_figure_wdlbknam=(PLCIO PLCIO)
IN/OUT:wd_mdb_proj_dbfnam=c:\open\work\FMT518.mdb IN:wd_mdb2_upd_prj_ixlst
IN:ace_proj_data IN/OUT:wd_mdb_proj_dbfnam=c:\open\work\FMT518.mdb
IN:wd_wdp_get_proj_file_lsts wd_1a_gn_getenv T==nil wd_1a_gn_getenv W (=nil
OUT:wd_wdp_get_proj_file_lsts OUT:ace_proj_data IN:wd_mdb_make_ixlst_visible
OUT:wd_mdb_make_ixlst_visible
IN/OUT:wd_mdb_proj_dbfnam=c:\open\work\FMT518.mdb OUT:wd_mdb2_upd_prj_ixlst
IN:ped_find_next_itemnum IN:wd_pitem_get_itemnum_lst
OUT:wd_pitem_get_itemnum_lst OUT:ped_find_next_itemnum018 IN:wd_bomr_entcat
IN/OUT:wd_1_get_pnlval MFG = IN/OUT:wd_1_get_attr_val h=42B0 nam=MFG = ABAB
IN/OUT:wd_1_get_pnlval CAT = IN/OUT:wd_1_get_attr_val h=42B0 nam=CAT =
1734-TB31734-TB3 IN/OUT:wd_1_get_pnlval ASSYCODE = IN/OUT:wd_1_get_attr_val
h=42B0 nam=ASSYCODE = IN/OUT:wd_1_get_pnlval CNT = IN/OUT:wd_1_get_attr_val
h=42B0 nam=CNT = IN/OUT:wd_1_get_pnlval UM = IN/OUT:wd_1_get_attr_val h=42B0
nam=UM = IN:wd_bomr_figure_wdblknam IN/OUT:wd_1_get_pnlval WDBLKNAM =
OUT:wd_bomr_figure_wdlbknam=(PLCIO PLCIO) IN:wd_pcatxx_getmulticat
= PLCIOPLCIO OUT:wd_pcatxx_getmulticat OUT:wd_bomr_entcat
IN:wd_ped_get_mg_on_dwg IN/OUT:wd_1_get_attr_val h=42D8 nam=INST =
IN/OUT:wd_1_get_attr_val h=42C4 nam=INST = IN/OUT:wd_1_get_attr_val h=42B0
nam=INST = IN/OUT:wd_1_get_attr_val h=4240 nam=INST = nil
IN/OUT:wd_1_get_attr_val h=4229 nam=INST = nil IN/OUT:wd_1_get_attr_val h=4212
nam=INST = nil IN/OUT:wd_1_get_attr_val h=41E2 nam=INST = nil
IN/OUT:wd_1_get_attr_val h=41CB nam=INST = nil IN/OUT:wd_1_get_attr_val h=41B4
nam=INST = nil IN/OUT:wd_1_get_attr_val h=419D nam=INST = nil
IN/OUT:wd_1_get_attr_val h=4186 nam=INST = nil IN/OUT:wd_1_get_attr_val h=416F
nam=INST = nil IN/OUT:wd_1_get_attr_val h=4158 nam=INST = nil
IN/OUT:wd_1_get_attr_val h=3E29 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3B28 nam=INST = nil IN/OUT:wd_1_get_attr_val h=3B22 nam=INST = nil
IN/OUT:wd_1_get_attr_val h=3B1C nam=INST = nil IN/OUT:wd_1_get_attr_val h=3B00
nam=INST = =617 IN/OUT:wd_1_get_attr_val h=3AEE nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3ADD nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3ACC nam=INST = =617 IN/OUT:wd_1_get_attr_val h=3935 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3923 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3911 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=38FF nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3832 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=34A0 nam=INST = IN/OUT:wd_1_get_attr_val h=3431 nam=INST =
IN/OUT:wd_1_get_attr_val h=341C nam=INST = IN/OUT:wd_1_get_attr_val h=33AF
nam=INST = =617 IN/OUT:wd_1_get_attr_val h=339D nam=INST = =617
IN/OUT:wd_1_get_attr_val h=338B nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3379 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=3367 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3355 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=32AA nam=INST = =617 IN/OUT:wd_1_get_attr_val h=328F nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3274 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3259 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=323E nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3223 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3208 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=315C nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3141 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3126 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=310B nam=INST = =617
IN/OUT:wd_1_get_attr_val h=3069 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3050 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=3037 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=301E nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=3005 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=2FEC nam=INST = =617
IN/OUT:wd_1_get_attr_val h=2FD3 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2FBA nam=INST = =617 IN/OUT:wd_1_get_attr_val h=2FA1 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=2F88 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2EE1 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=2E36 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=2D7B nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2D69 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=2D57 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=2D45 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2D33 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=2D21 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=2D0C nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2901 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=28AF nam=INST = =617
IN/OUT:wd_1_get_attr_val h=285D nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=280B nam=INST = =617 IN/OUT:wd_1_get_attr_val h=27B9 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=2767 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2715 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=26C3 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=2671 nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=261F nam=INST = =617 IN/OUT:wd_1_get_attr_val h=25CD nam=INST = =617
IN/OUT:wd_1_get_attr_val h=257B nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2529 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=2327 nam=INST = =617
IN/OUT:wd_1_get_attr_val h=226B nam=INST = =617 IN/OUT:wd_1_get_attr_val
h=2218 nam=INST = =617 IN/OUT:wd_1_get_attr_val h=272 nam=INST = nil
OUT:wd_ped_get_mg_on_dwg IN:wd_pcatxx_calc_netchg add=nil del=nil
OUT:wd_pcatxx_calc_netchg=nil OUT:wd_ped_doedit IN:wd_plo_edit_update3
en=in_flg=nil old=(PIO617-1513 =617 +EN5 AB 1734-TB3
RACK 2 SLOT 2 DIGITAL INPUT PLCIO ( ) x) new=(PIO617-1513 =617 +EN5 AB
1734-TB3 RACK 2 SLOT 2 DIGITAL INPUT PLCIO ( ) 0) IN/OUT:wd_1_get_pnlval FPT =
IN/OUT:wd_1_get_attr_val h=42B0 nam=FPT = nilnil IN:wd_bomr_entcat
IN:wd_pitem_add_d_itemlst OUT:wd_pitem_add_d_itemlst
IN/OUT:wd_1_get_pnlval LINKTERM = IN/OUT:wd_1_get_attr_val h=42B0 nam=LINKTERM
= nilnil IN:wd_pcatxx_calc_netchg add=nil del=nil
OUT:wd_pcatxx_calc_netchg=nil OUT:wd_plo_edit_update3 IN/OUT:wd_1_get_pnlval
NP = IN/OUT:wd_1_get_attr_val h=42B0 nam=NP = nilnil OUT:wd_ped_pnl_comp
OUT:wd_psymed
