I have added a 2005 install to my system, along with 2004.
We use a network based catalog, symbol library, etc. The catalog currently in use is a merge between our custom 2004 cat and the new 2005 catalog. Consequently, there are some tables that have 'CAT' and 'MFG' column headings spelled out (the 2005 tables), and the custom tables created in 2004 do not. Also, the pinlist table has been made compatible with 2004, but it appears to work fine in 2005 (the reverse is not true).
To set up 2005 to work with these network items, I added a Support File Search Path in ACAD Options for this network location. I also compared the 2005 wd.env file to my current wd.env, and I did not see any new changes, so I substituted my custom 2004 wd.env file for the 2005 wd.env. This basically tells ACADE to find the catalog and symbol libraries on the network, not my computer.
Problem: When clicking on the Insert PLC button, I simply get an error message that says C:\....\plc\ACE_PLC.MDB cannot be found. The "plc" directory and .mdb file are in fact present in the location ACADE is saying that it is looking for it, yet ACADE is saying it can't find it.
None of the changes I made to the ACADE and wd.env configurations (listed above) should have caused this problem.
Questions:
Is 2005 sensitive to the 2004 column headings in our custom tables ('CAT' and 'MFG')? (i.e., should I go through the cat.mdb and make sure all the 2004 generated tables match the format of the 2005 tables?)
Are there symbols or changes in the new JIC125 directory that are not in the 2004 symbol library? (i.e., should I copy over the JIC125 symbols on our network from the 2005 library?)
Are there changes in the symbol Icon menu between 2004 and 2005?
Are there any other update issues that a network user like myself might run into?
Thanks!
- Jay
