I use a wiring diagram style terminal footprint, which allows me to use the Schematic Wire Connections > Footprint tool to add wire information, such as wire number, wire layer, and even the component the other end of the wire connects to. The panel layout will then have a visual reference as to the specific wire that connects to each terminal. I will attach one of my terminal blocks as a reference. This is an Entrelec M4/6, or part number 115 116.07 feed-through terminal.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
