• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    view contours
    145 Views, 4 Replies
    12-28-2012 01:08 PM
    I have a surface with a bunch of contours. I want to view the contours at elevation 550. In Microstation there is a set display depth command. Is there a tool in autocad where I can view certain elevations.
    I want to make layouts/viewports that are clipped to different elevations. For example I have a surface with 5' contours. I want to create multiple viewports on a sheet showing what each contour looks like at its elevation.
    Civil 3D 2012 SP3.0 Windows 7 Enterprise 64-bit
    Dell M6600, Core i7 @ 2.3GHz, 16 GB ram
    Please use plain text.
    *Pro
    Re: view contours
    12-28-2012 01:18 PM in reply to: lambertb
    there is a user defined contour setting in the surface style under the analysis tab.   You can define as many of these as you like and specify the elevations.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Joe-Bouza
    Re: view contours
    12-29-2012 01:57 PM in reply to: lambertb
    There is thta view dohickey that changes display concentration based on zoom level, but I think you'll need a surface display style to control the contours you want to see.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    BrianHailey
    Re: view contours
    12-30-2012 04:52 PM in reply to: lambertb
    Others have pointed you in the right direction but I just gotta ask, Why are you doing this? I've never heard of anyone c reating viewports clipped to the extents of specific elevations before. What kind of project is this? I'm not trying to be sarcastic or anything like that, I'm truly curious.
    Re: view contours
    12-31-2012 06:17 AM in reply to: BrianHailey
    We are showing plan sections of an earthen dam embankment. It was requested. I don't think is is going to be dynamically possible so we may have to explode the surface or try the user defined contours. Maybe that will allow one to turn off individual layers in the viewport.
    I have done this a lot for design. I view certain contours intervals to find boundaries needed. Is there a way to clip views based on elevations in AutoCAD?
