• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    tjshaffer
    Re: unselectable/disappearing viewports
    10-26-2012 08:53 AM in reply to: demus72
    Unfortunately, this still happens to me too.  After repeatedly trying different work-arounds I found this to be the easiest way to select my vport: 1] select the Pspace tab you need to be in  2] in 'Properties' palette click on 'Quick Select' at top right then in the 'Object type' drop-down select 'Viewport. "Value' field is ByLayer (see attached 'Quick Select' screen shot for settings).  3] Click OK and you should see the vport highlighted with grips.
    Please use plain text.
