• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Joe-Bouza
    trouble exporting to plain autocad
    151 Views, 8 Replies
    06-28-2012 02:46 PM
    If I audit or recover this file I get no errors, but if I try to export or batch and explode aec object I get error...try recover and no file gets created. Any suggestions?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    Re: trouble exporting to plain autocad
    06-28-2012 04:36 PM in reply to: Joe-Bouza
    Hi Joe,
    Can you Exportotautocadr12dxf? I usually go to this format as a standby when nothing else works. Maybe it will work for you.
    Tim
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Joe-Bouza
    06-28-2012 07:03 PM in reply to: tcorey
    Hi Tim
    Thanks, that should work, I'll give it a go in the morning
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Active Contributor
    06-28-2012 10:41 PM in reply to: Joe-Bouza
    This happens to me too.  I do not want a DXF file, I would like to export to AutoCAD like it's supposed to.
    Carl M. Fiorica, P.E., LEED A.P.
    Burkett and Wong Engineers
    3434 4th Ave
    San Diego, CA 92103
    neilyj
    06-29-2012 02:31 AM in reply to: Joe-Bouza
    I've had issues when XREF's are in the drawing.
    I do a SAVEAS, BIND the Xrefs and EXPORT then CLOSE the drawing without Saving - seems to work
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Joe-Bouza
    06-29-2012 06:19 AM in reply to: neilyj
    I'm still having trouble, I don't have xrefs but do have datalinks that cannot be bound, detached  or unloaded? I thimks I PDF is my only option
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    neilyj
    06-29-2012 06:51 AM in reply to: Joe-Bouza
    What about DWF ??
    If you are wanting to use as an underlay, I have had much better results with a DWF rather than a pdf
    neilyj
    johnm
    06-29-2012 07:36 AM in reply to: Joe-Bouza
    I agree with that Neil. Popping a pdf into a dwg is the best way I know to make AutoCAD slow to a crawl.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Joe-Bouza
    06-29-2012 08:48 AM in reply to: johnm
    Dwf, PDF, it make no diff to me I'm sending the drawing out.
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
