• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    tool palette dock and closed
    170 Views, 12 Replies
    10-24-2012 10:07 AM
    i am getting a message when i click on something from my tool palette saying that it does not display when it is docked and closed. how do i undo this so i can use objects from the tool palette. how do i "unlock" it? see image.
    thanks.
    Please use plain text.
    AllenJessup
    Re: tool palette dock and closed
    10-24-2012 10:13 AM in reply to: MonkeyTrainer
    CTRL + F3 should open the toolpallet. Then you can undock it if you want.
    Allen
    10-24-2012 10:15 AM in reply to: AllenJessup
    unLOCK. it doesnt matter if its DOCKED or not
    thanks.
    AllenJessup
    10-24-2012 10:20 AM in reply to: AllenJessup
    Sorry. Should be CTRL + F1 for the Properties Pallet. Or select an entity, rt click and select properties from the menu.
    Allen
    10-24-2012 10:23 AM in reply to: AllenJessup
    ok, maybe im not being clear enough. the objects on my tool palette are locked. thats it.
    thanks for posting.
    AllenJessup
    10-24-2012 10:24 AM in reply to: MonkeyTrainer
    After rereading your post and the attached error. I'm thinking that the something you're click on in the toolpalette is a subassembly or other item that has properties editable in the Properties palette. So you need to open your Properties window.
    Allen
    10-24-2012 10:26 AM in reply to: AllenJessup
    ok, there is nothing editable in the properties box referring to an object being lockable.
    AllenJessup
    10-24-2012 10:26 AM in reply to: MonkeyTrainer
    Or I'm being dense today. I don't know how to Lock a toolpalette so I can't say how to Unlock it. At this point my best guess is that you need to open your Properties Palette.
    Allen
    10-24-2012 10:28 AM in reply to: AllenJessup
    do you know how to do that besides CTRL + F1? we changed our script for the f1 key.
    AllenJessup
    10-24-2012 10:28 AM in reply to: MonkeyTrainer
    We keep crossing our post. So your latest invalidates my latest. From reading the error message that was the best I could come up with.
    Allen
