• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    jmatte2004
    survey database coordinates off
    165 Views, 3 Replies
    02-23-2012 10:01 AM
    i have a point file specifically a PNEZD file. when i import points into the survey database the coordinate in the database is correct but the coordinate on the drawing tends to be 5 feet off one way and 1 foot off the other. When I import point through the points pull-down menu the coordinates are correctly shown. When I import point into survey database from drawing the coordinate is incorrect in the database but correct on screen. Any help about what might be going on here.
    jason
    Please use plain text.
    Re: survey database coordinates off
    02-23-2012 10:54 AM in reply to: jmatte2004
    Check to be sure you have set either International Feet or US Survey foot in both the Drawing Settings and the Survey Database Settings. Having one of these set to International and the other to US will cause a problem like what you describe.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Contributor
    jmatte2004
    02-23-2012 11:33 AM in reply to: tcorey
    thanks tcorey that was the problem. our templete drawing was set to international foot something i never thought about.
    thanks again
    jason
    Valued Mentor
    02-23-2012 11:56 AM in reply to: jmatte2004
    You should also be aware that any transformation settings you have set to the drawing will be applied during an import from the database.
