• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    aluko0719
    Accepted Solution
    surface does not dispaly when i open the drawing
    293 Views, 16 Replies
    02-14-2013 08:43 AM
    i have a surface that is data linked into a drawing. the surface displays good in paper and model space. when i save and close out of the drawing and get back into the drawing the surface no longer displays. in toolspace, surface, the surface is listed. when i synchronize the surface it displays again, but when i save, close, and reopen it is not there again. i have no clue why it is doing this. there are 10 drawings in this project and it is doing this for 8 of them. other jobs are fine. i have tried using different computers and i get the same results (tried on 5 different computers).
    Please use plain text.
    Active Contributor
    w_davis
    Re: surface does not dispaly when i open the drawing
    02-14-2013 08:49 AM in reply to: aluko0719
    Maybe right click on the surface in Toolspace and chose rebuild automatic?
    Active Member
    aluko0719
    02-14-2013 09:34 AM in reply to: w_davis
    it is already has that to be automatic
    *Expert Elite*
    02-14-2013 09:50 AM in reply to: aluko0719
    What version are you running?  I've heard that newer versions than mine have a "level of detail" option which controls how much a surface will display, depending on zoom level.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Member
    aluko0719
    02-14-2013 10:12 AM in reply to: troma
    windows 7 64 bit 8 gig ram, 2013. level of detail is turned off. i think that we have narrowed the problem down to either a pipe network problem or a xref problem
    Active Member
    02-14-2013 12:42 PM in reply to: aluko0719
    the surface doesn't have any errors when rebuilding?
    this has happened to me before and the problem was resolved when carefully fixed overlaping feature lines or even boundary objects crossing feature lines.
    Strangely enough, and certainly not a fix to your problemf, i found selecting the surface from toolspace, deleting it, then undoing the delete made the surface display.
    Tyler H. Johnson
    Civil3d 2013
    Dell Precision T3500
    Intel Xeon
    24GB Ram
    64Bit Win7 Pro
    dseatter
    02-19-2013 08:42 AM in reply to: OsnapBhatch
    I have had this problem when my surface is rather large such as when created from contours from LIDAR data.
    I found that if I change the surface style to one that shows the triangles the surface will display.
    I then change the style back to the one I want and it displays. I don't know why this works, but it
    is the way I can make the surface display. Hope this helps.
    Dave Seatter, PLS
    C3D 2013 SP1
    Win 7 x64 Pro SP1 - 12.0 GB RAM
    Intel Xeon W3530@2.8 GHz - ATI FirePro 4800
    Dell T3500
    Active Member
    aluko0719
    Re: surface does not display when I open the drawing
    02-19-2013 08:45 AM in reply to: dseatter
    I'll give that I try. My surface is somewhat large and it does use lidar
    03-04-2013 12:16 PM in reply to: aluko0719
    I am having a similar problem on a surface.  My only work around is to sync the surface after open. Again like others not a solution but it seems to work.  This is frustrating because the point of the dynamic is to automate these things.
    Active Member
    aluko0719
    03-04-2013 12:41 PM in reply to: JWOLLENBERG
    Sync works but I have to sync every time I get into the drawing and you can't publish the drawings because the surface does not show up.
