• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    style, text insert
    118 Views, 5 Replies
    04-24-2012 11:29 AM
    Can a expresion be use for text anchor point or Attachement?
    I looking at using the ML or MR based on if the distance is Plus or Minus.
    Please use plain text.
    Product Support
    machadt
    Re: style, text insert
    04-26-2012 04:44 PM in reply to: rfg018
    Hi Robert<
    I am not sure what your question is, could you please give more details on what you would like to accomplish?
    Thank you,
    Tatiana Machado
    Americas AEC Infrastructure Product Support Specialist
    Autodesk, Inc.
    *Expert Elite*
    BrianHailey
    04-26-2012 09:54 PM in reply to: rfg018
    Unfortunately, the only thing an expression will return is a number. You can use that number in the X and Y offset to adjust the label but you can change the attachment point using an expression. I've longed for the time that an expression would return a string or even a boolean but alas, currently it only returns a number.
    04-27-2012 07:55 AM in reply to: rfg018
    I want to have a Label, with two component, I have an expression  to rotate the text (perper to mirror), and I have the text to plan read, the problem is the two componet, are in the wrong place.
    With plan read off, the text is in the wrong place.  My options it to have style for each options/angle, but since I'm using reference text, ever time I change the stye, the reference text goes to none.  Plus this take time.
    I going to look at using the x y offset, but I'm not sure If I can calc the length of the text.
    Thanks for the idea.
    Product Support
    machadt
    04-27-2012 08:59 AM in reply to: rfg018
    Maybe if you show us an image of what you would like to do, we could give you some ideas.
    Tatiana Machado
    Autodesk, Inc.
    *Expert Elite*
    BrianHailey
    04-27-2012 03:50 PM in reply to: rfg018
    Not exactly sure what you are trying (as Tatiana suggests, perhaps an image would help us). Also, check out the "Flip Anchors with Text" option. Perhaps that will help you get what you want.
