• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    stop and go corridor on alignment
    123 Views, 4 Replies
    03-19-2012 09:25 AM
    I want use my corridor where I need it and not use one in certain areas. For a proposed dike. Some places doesn't need to be replace.
    So I need a way to use my section on the alignment.
    Anybody know where I can find that option?
    Please use plain text.
    Joe-Bouza
    Re: stop and go corridor on alignment
    03-19-2012 10:36 AM in reply to: kmans57
    divide your cooridor into regions and only use the portions needed..
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    sboon
    03-19-2012 11:48 AM in reply to: Joe-Bouza
    Joe's method will work but you may find that the featurelines created by the corridor span across the gaps between regions.  The way around this problem is to create a Null assembly (an assembly with no subassemblies attached to it) and use that for the regions where you need a gap.
    There is another possible issue in that the corridor surfaces will span across the gaps, so your volume calcs may be affected.  There are a few possible solutions for that problem - depending on how the corridor is created.
    Joe-Bouza
    03-19-2012 06:27 PM in reply to: sboon
    even when yahide em?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    sboon
    03-19-2012 08:00 PM in reply to: Joe-Bouza
    Depends on how you do the calc.  Surface to surface will be affected by the surface hide boundary, but end area or prismoidal calcs may not.
