station offset labels of blocks
maybe someone can help me. if anyone has a style or know how to set-up a style what i want to do is label the station and offset of the insertion point of a block by selecting that block and placing the name of the block at the end of the label. as such it would read sta: 14+58.25 - L12.50' P Pole
thank you
jason m.
SethHall
The best solution I could come up with off the top of my head is that if that "P Pole" originated from a point, you could create a reference text component of the Station/Offset label that pulls the cogo point name. This could easily accomplish what you are describing, however you need the point to be in that location.
Seth Hall
Product Owner
Model Builder
Joe-Bouza
Adding the Seth's suggestion: if you do not have the points you can extract the block info to csv then import as a point file, and you'll have it.
Joe Bouza
that would work seth
