• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    fcernst
    Re: shoulder slope subassembly
    01-23-2013 06:15 AM in reply to: KMercier_C3D
    Right, that figure he posted, you may not have seen it, shows the OP's shoulder slope criteria is not a simple direct relationship to lane slope.
    Ernst Engineering
    Fred Ernst, PE
    C3D 2013 SP1, C3D 2014
    W7x64; i7 8gb; Radeon HD 5700
    www.ernstengineering.com
    Please use plain text.
    Distinguished Contributor
    01-23-2013 06:16 AM in reply to: KMercier_C3D
    thanks for all the input.
    no, the shoulder doesn't match the lane slope all the time, only in certain instances where the lane slope is greater than 6%. between -1% and 6% the shoulder stays at 6%. from -1% to -5% the shoulder varies in relation to the lane slope. if the lane slope is -3.2% then the shoulder slope is 3.8%. at -6% and greater it becomes crowned. it is a pita. like i said, i've got a profile for the shoulder but any change in alignment or profile really becomes time consuming.
    Dell Studio XPS 9100
    Intel Core i7 CPU 930 @ 2.8GHz
    12GB Ram
    64 bit
    C3D 2012 SP2
    KMercier_C3D
    01-23-2013 06:19 AM in reply to: fcernst
    I stand corrected. I had missed the *.png that was posted. Definitely an ideal situation for SAC and really a rather simple one at that. I'd still use Parameter References though and have the shoulder SAC have an input parameter of the lane slope and then the shoulder is calculated and generated from there.
    Kati Mercier, P.E.
    Co-author of "Mastering AutoCAD Civil 3D 2013"
    AutoCAD Civil 3D 2013 Certified Professional and AutoCAD 2013 Certified Professional
    AU2012 Speaker::: CI3001: Reverse Engineering with Subassembly Composer for AutoCAD Civil 3D
    AU2011 Speaker::: CI4252: Create Subassemblies That Think Outside the Box With Subassembly Composer for AutoCAD® Civil 3D®
    Valued Mentor
    fcernst
    01-23-2013 06:25 AM in reply to: KMercier_C3D
    Yes, that would work through most of the criteria range, except for those steep lane slopes at the top of the criteria range, where it looks like he has a crowned shoulder that is smoothed with a fillet, which SAC could easily handle.
    Ernst Engineering
    Fred Ernst, PE
