• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    shift click
    295 Views, 11 Replies
    11-05-2012 06:16 AM
    a normal day is when i have a group of somethings selected, and when i hold shift and click some of those selected somethings, they will unselect. like, you window a group of objects, but then decide to de-select something.
    now, when i have a group of objects select, and shift click, it doesn't de-select the object, my command line reads "1 image(s) found". how do i get the shift-click back to de-selecting something?
    Please use plain text.
    Re: shift click
    11-05-2012 06:24 AM in reply to: MonkeyTrainer
    I read this recently I will try and look it up for you... I rememeber there is a map setting you can disable to keep this from happening.
    -Dustin
    Civil 3D 2013 64 bit SP1
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    NVIDIA Quadro FX 580
    explodetheblock.wordpress.com
    Re: shift click
    11-05-2012 06:37 AM in reply to: MonkeyTrainer
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/1-image-s-found/m-p/2831495/highlight/true#M140853
    imapoptions
    general tab
    turn off shift+left click
    -Dustin
    Windows 7 Pro 64
    Intel Xeon 2.93GHz
    24GB RAM
    *Expert Elite*
    johnm
    Re: shift click
    11-05-2012 06:38 AM in reply to: MonkeyTrainer
    Raster Design would do this. If it's intalled go to the Raster Design Options dialog, User Preferences tab and uncheck the box for Shift+Left click image select.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Re: shift click
    11-05-2012 06:45 AM in reply to: johnm
    i dont currently have that installed. is there a text prompt that pops up on the command line someone could post for me that enables/disables this feature?
    *Expert Elite*
    TRogers
    Re: shift click
    11-05-2012 07:01 AM in reply to: MonkeyTrainer
    For some reason in 2013, the Noun/Verb selection keeps turning itself off.  In the Options, Selection tab, make sure that Noun/Verb Selection is checked.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Re: shift click
    11-05-2012 07:21 AM in reply to: TRogers
    my box was checked. i also tried unselecting, hitting ok, then checking it again. it still is saying the above quote.
    thanks.
    *Expert Elite*
    TRogers
    Re: shift click
    11-05-2012 07:22 AM in reply to: MonkeyTrainer
    Mine did this the other day and a simple reboot of the program fixed it.
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    *Expert Elite*
    Re: shift click
    11-05-2012 04:11 PM in reply to: MonkeyTrainer
    From the Command prompt, type MAPIOPTIONS, go to General tab, turn off the option to Shift+Left Click Image Select. Now Shift+Left click will de-select objects.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    *Expert Elite*
    Re: shift click
    11-06-2012 06:37 AM in reply to: tcorey
    So we Shift+click to deselct objects in a selection set, we Shift+click to select grips of selected objects, and now we can Shift+click to select an image too!  Isn't anyone thinking?  What's wrong with Ctrl+click or Alt+click, if we need more clicking options?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
