AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: set multiple polyline elevations for contour data
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The UKIE Toolbox is presumambly available to users in the UK and Ireland. Since the OP is using imperial units, I doubt it is an option.
Why such a tool would be provided to some users and not others I can't imagine.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It can be installed from any C3D installation..although if you use Deployments I would imagine it would need to be included in that.
You can add the UKIE Content pack after installation by going to Windows' Remove programs, select the version of C3D you are using, at the screen to choose to Uninstall, reinstall, repair, etc., choose Add or Remove Features, then check the UKIE Content.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good to know.
Still don't understand why a tool like this would be hidden away in a country kit, even if it is available to all.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Unless you have that tool available there is no need to change the 2d contours to 3d. I did find a tool I wasn't aware of in the Modify Tab under Design that allows you to directly edit the elevation of a polyline without having to bring up the properties dialogue box. Unfortunately it only works on one polyline at a time.
Definately use the polyline edit multiple and join the 50 ft segments together rather than editing each segment.
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
6Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
