• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Re: set multiple polyline elevations for contour data
    11-13-2012 11:21 AM in reply to: mikeevans
    The UKIE Toolbox is presumambly available to users in the UK and Ireland.  Since the OP is using imperial units, I doubt it is an option.
    Why such a tool would be provided to some users and not others I can't imagine.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    11-13-2012 11:33 AM in reply to: troma
    It can be installed from any C3D installation..although if you use Deployments I would imagine it would need to be included in that.
    You can add the UKIE Content pack after installation by going to Windows' Remove programs, select the version of C3D you are using, at the screen to choose to Uninstall, reinstall, repair, etc., choose Add or Remove Features, then check the UKIE Content.
    11-13-2012 11:42 AM in reply to: Jeff_M
    Good to know.
    Still don't understand why a tool like this would be hidden away in a country kit, even if it is available to all.
    *Pro
    11-29-2012 10:33 AM in reply to: mikeevans
    Unless you have that tool available there is no need to change the 2d contours to 3d.   I did find a tool I wasn't aware of in the Modify Tab under Design that allows you to directly edit the elevation of a polyline without having to bring up the properties dialogue box.   Unfortunately it only works on one polyline at a time.
    Definately use the polyline edit multiple and join the 50 ft segments together rather than editing each segment.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Valued Contributor
    C3D_TomR
    11-30-2012 02:15 PM in reply to: kas022
