• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Joe Bouza
    section views and corridor scenarios
    285 Views, 13 Replies
    05-13-2010 09:30 AM
    I have created a corridor, surface , sections and
    qty, and want to explore another scenario. So I added another baseline, assembly
    and targets, and turnes off the baselines from the previous scenario - the plan
    looked great, but the first corridor is still in the section view. How can I
    turn one off and have the second show? I would have thunk turning off the other
    base line would have done that but it doesn't.
    I realize I could make another corridor and surface
    and add to the section views, but that seems antithetical the the tenets of the
    software, no?
    Thanks, Joe
    Joseph D. Bouza, P.E. (one of 'THOSE' People)
    Civil 3D 2008
    Win XP
    pro
    v 2002, sp 2
    hp workstation xw4600
    Intel Core Duo CPU
    E7200
    @2.53 GHz
    3 GB RAM
    NIVDIA Quadro FX 1700
    (512MB)
    "All Contours are Lies! "-(
    AJ)
    The mantra of a former Flamer:
    If you
    are forced to eat an Elephant, don’t complain about it; Take one bite at a
    time.
    In
    memory of the King of Work-arounds
    "The only Constant is Change".
    "The only thing worse than training your staff, and having them leave is
    not training your staff, and having them stay." :-o
    A reminder taken
    from Graphics Solution Providers' Calendar
    page
    "An
    Equal Opportunity Annoyer" (DK)
    Please use plain text.
    *wfb
    Re: section views and corridor scenarios
    05-13-2010 09:51 AM in reply to: *Joe Bouza
    Joe:
    Can you select different baselines under Corridor
    in "Mr. Prospector"?
    Bill
    style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px"
    dir=ltr>
    assembly and targets, and turnes off the baselines from the previous scenario
    - the plan looked great, but the first corridor is still in the section view.
    How can I turn one off and have the second show? I would have thunk turning
    off the other base line would have done that but it doesn't.
    surface and add to the section views, but that seems antithetical the the
    tenets of the software, no?
    Thanks, Joe
    Civil 3D 2008
    Win XP
    pro
    v 2002, sp 2
    Intel Core Duo CPU
    E7200
    @2.53 GHz
    3 GB RAM
    (512MB)
    AJ)
    If you
    time.
    In
    A reminder taken
    page
    "An
    *Joe Bouza
    05-13-2010 09:54 AM in reply to: *Joe Bouza
    No. Only in the corridor properties dialog
    box.
    Joe
    *John Mayo, PE
    05-13-2010 10:40 AM in reply to: *Joe Bouza
    Save As.
    Keep the different scenarios in different
    files.
    Thunk??  I think you need a, 'woulda' prefix to really make that
    work. Winking smile emoticon
    John Mayo, PE
    Win 7 64, C3D & RD 2010
    Core i7 920, 6 GB DDR3
    Quadro FX
    1700
    *Matt Kolberg
    05-13-2010 11:00 AM in reply to: *Joe Bouza
    Right click any of the section view, Section View
    Group Properties.
    Sections tab
    Uncheck what you don't want.
    Matt Kolberg
    Global CADD Systems - A division of Cansel
    dir=ltr>
    Thanks, Joe
    Civil 3D 2008
    Win XP
    pro
    v 2002, sp 2
    Intel Core Duo CPU
    E7200
    @2.53 GHz
    3 GB RAM
    (512MB)
    AJ)
    If you
    time.
    In
    A reminder taken
    page
    "An
    *Joe Bouza
    05-13-2010 11:58 AM in reply to: *Joe Bouza
    I'll use that advice, but shouldn't turning of
    baselines remove any associated sections?
    Thanks, Joe
    *Joe Bouza
    05-13-2010 01:50 PM in reply to: *Joe Bouza
    That isn't an option since scenario 2 and scenario
    1 are the same corridor. I turned off all the scenario 1 baselines and the
    corridor line go away in plan as expected. I add scenario 2 base line and the
    corridor line display in plan as expected but scenario 1 stay visible in the
    section view even though they are not visible in corridor view.
    I thought the hole idea was and I paraphrase from
    the marketing material..."...Instantly visualize different scenarios with
    civil3d corridors.... blah bla blah..."
    momentarily frustrated,
    Joe
    *Matt Kolberg
    05-13-2010 02:49 PM in reply to: *Joe Bouza
    Duh, of course.  My bad.
    What's the problem with making 2 corridors?
    it'd be easy then.  You're doing all the same with with the extra baseline
    anyway...
    Matt Kolberg
    dir=ltr>
    scenario 1 are the same corridor. I turned off all the scenario 1 baselines
    and the corridor line go away in plan as expected. I add scenario 2 base line
    and the corridor line display in plan as expected but scenario 1 stay visible
    in the section view even though they are not visible in corridor
    view.
    Joe
    *Joe Bouza
    05-14-2010 05:06 AM in reply to: *Joe Bouza
    I guess that true - I thought I could do it this
    way and toggle between scenarios for comparison, plus have less
    clutter.
    P.S while I have you Matt, are you familiar with
    the OverlayEdgetoCrown Assembly? I'd like to add a pavement section and or curb
    to the edge but the corridor goes kabluey when I do. the attachenment nodes are
    there but it seems to not keep the overlay offset.
    I'm going to try a workaround by creating the
    overlay surface and extract profile from corridor and the attach a final road
    assembly.
    Thanks, Joe
    Valued Mentor
    05-14-2010 05:26 AM in reply to: *Joe Bouza
    Whack the Corridor section 1 and 2 on different Layers, freeze and thaw accordingly or vpfreeze/thaw.
    You then won't see them on the sections.
    At least that's what I do.
