• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    section editor view width
    140 Views, 2 Replies
    11-14-2012 06:40 AM
    when i get into my section editor, the view is zoomed out too far. is there a way to change the width of this view? i looked in display options, but may have skipped over the solution.
    thanks.
    Please use plain text.
    sboon
    Re: section editor view width
    11-14-2012 08:15 AM in reply to: MonkeyTrainer
    There should be an option for default zoom scale or factor.  Make sure that is set to 1 and see what happens.  Something else to keep in mind is that the default view is supposed to include the extents of the corridor section.  If you have a targeting error or a bad elevation far away from the baseline then the software will try to show that.
    11-14-2012 08:22 AM in reply to: sboon
    ok, you're right. i looked over that and found it in "view/edit options". thanks.
