• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    sampleline extend
    164 Views, 2 Replies
    12-26-2012 05:52 PM
    I want to extend sampleline along matchline for creating cross section view.
    I used Modify-extend in hometab, but it doen't work.
    What shall I do?
    magenta color is matchline,
    I attch screenshot.
    Please use plain text.
    Product Support
    AlmasSuljevic
    Re: sampleline extend
    01-02-2013 08:26 AM in reply to: dreaminglisa3
    You can only create sample lines along the alignment. If you want to extend sample lines you can grip-edit them.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Please click on "Accept as Solution" if post helped you resolve the issue.
    01-02-2013 08:27 AM in reply to: dreaminglisa3
    You can click on the sample line and drag it longer.
    Or you can start again.  Delete the old ones and make the new ones bigger.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
