• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    rt lisp routine
    194 Views, 7 Replies
    10-22-2012 12:43 PM
    when I load a lisp routine "rt".... it wipes my osnap settings.
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: rt lisp routine
    10-22-2012 01:39 PM in reply to: toonook77777
    It's the (SETVAR "OSMODE" 1) that is doing this (resets to endpoint, presumably as part of the lisp routine). I don't know what the lisp is doing (rotating a view perhaps??) as I'm not a lisp expert - there are other contributors to the forum who are and may be able to suggest something.
    As an aside, I have put my preferred OSNAPS in a right click macro so i can always reset if i need to temporarily alter them.
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Member
    Re: rt lisp routine
    10-22-2012 01:44 PM in reply to: neilyj
    so OSMODE 1 is what is killing my osnaps? What should it be set to to prevent this?
    *Expert Elite*
    AllenJessup
    Re: rt lisp routine
    10-22-2012 01:56 PM in reply to: toonook77777
    I don't have time now. But if no one has chimed in on how to use GETVAR to save the OSMode. I'll get back to you in the morning.
    Allen
    *Expert Elite*
    neilyj
    Re: rt lisp routine
    10-22-2012 02:31 PM in reply to: toonook77777
    i guess you could reset the osmode at the end of the lisp. Allen is one of the lisp gurus i mentioned so will give better advice than me. you will need to obtain the osmode value that corresponds to your preferred settings. Set them via options as usual and type OSMODE and note the value displayed (help will explain how the value is derived)
    neilyj
    *Expert Elite*
    AllenJessup
    Re: rt lisp routine
    10-23-2012 04:50 AM in reply to: toonook77777
    OK. Since you probably don't write much lisp. The easiest way to fix this would be to add 2 lines to the lisp code. Add the bold line where shown.
    C:RT ()
    (setvar "cmdecho" 0)
    (setq OM (getvar "osmode"))
    (setq OB (entsel "\Select object for base angle: "))
    Add this line near the end of the lisp.
    (setvar "osmode" OM)
    The first line sets the current osmode to the variable OM. The second line resets the osmode using the OM variable.
    Allen
    *Expert Elite*
    AllenJessup
    Re: rt lisp routine
    10-23-2012 04:55 AM in reply to: neilyj
    Sorry to dissuade you Neil. But I'm just a dabbler. I stopped doing anything serious in lisp when autodesk and third party covered most of what I wanted to do. The only things I can do in VLisp is to paste together some things by example.
    Allen
    *Expert Elite*
    neilyj
    Re: rt lisp routine
    10-23-2012 05:29 AM in reply to: AllenJessup
    If you can anything in lisp - you are a guru...:smileywink:
    neilyj
