• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    rong command come with nil word
    136 Views, 5 Replies
    01-13-2013 05:14 AM
    hi...
    i need help
    whil working with civil 3d after awhile aproblems appear
    for example
    i give it command s (stretch) it do QSave or comand C it do copy but i checked command allias and it's ok, some short cuts dosn't work just give me in command line (comannd: nil) and other setting when i change it return back to defult after i close window
    so i reinstaled and it worked good but after one day it happen again
    any idea why this happen
    Please use plain text.
    *Expert Elite*
    Re: rong command come with nil word
    01-13-2013 07:47 AM in reply to: ADAcivil
    The only thing that comes to mind is perhaps you are starting the "Autocad Civil 3D as AutoCad".  This means you are using vanilla AutoCAD with no Civil 3D commands.
    Bill
    Member
    01-15-2013 01:25 AM in reply to: ADAcivil
    still has the proplem i setupet anti virose and  reinstaled the programe and same proplem pls i need help
    Member
    01-15-2013 01:32 AM in reply to: ADAcivil
    for example if i type ex (extend) here what come
    Command: ex
    EXPLODE nil
    Select object:
    or r as redw here what come
    Command: r 'REDRAWALL
    Command: nil
    or s (stretch) here what come
    Command: s
    QSAVE Save drawing as <C:\Users\a.elmekawy\Documents\Drawing1.dwg>: nil
    and that happen awhile after i setup the programe.
    so any idea.....??
    *Expert Elite*
    AllenJessup
    01-15-2013 05:27 AM in reply to: ADAcivil
    Are you running 3rd party software that may be overwriting your Aliases?
    Are you sure you are checking - editing the right acad.pgp file? Type (findfile "acad.pgp") at the command line. That will show you the path to the pgp file you're using.
    Member
    01-19-2013 10:02 PM in reply to: ADAcivil
    sorry but it didn't work and i still have the proplem and it getting me crazy even after i setuped civil 2013
