• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    wang890
    reset drawing scale list
    615 Views, 6 Replies
    09-18-2012 05:27 PM
    before when reset scale it will have 1:1000, 1:2000, something like that.
    now when reset it is same as autocad. which is like 1:1 (should be 1000), 1:2 (should be 2000)
    what changed? i know it's just the name but this is bad. shoudln't change something like this all the sudden. hopefully is some variable.
    working in metric.
    Civil 3D 2012
    Work: Xeon W3503, 12GB, Quadro 2000, Dell 19' x 2
    Home: 3930k, 16GB, GTX 590, Dell U3011
    Please use plain text.
    *Expert Elite*
    Re: reset drawing scale list
    09-18-2012 08:44 PM in reply to: wang890
    Your default setting have changed. They are set in the registry. You can open the Options dialog and set the default scale list to whatever you need.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    Active Contributor
    gjcbachman
    09-19-2012 07:18 AM in reply to: wang890
    What is the command for resetting the drawing scale list?  That will come in handy.
    Lisa
    Windows 7 x 64
    AMD Phenom II X4 945 3.00 GHz
    16 GB RAM
    NVIDIA Quadro 2000
    Civil 3D 2013 (G.114.0.0, SP1)
    Active Member
    09-19-2012 07:41 AM in reply to: wang890
    the command is "SCALELISTEDIT"  if you use it often like i do, creating an alias such as "SLE" is a good idea:smileyhappy:
    ______________________________
    Tyler H. Johnson
    Civil3d 2013
    Dell Precision T3500
    Intel Xeon
    24GB Ram
    64Bit Win7 Pro
    wang890
    09-19-2012 11:26 AM in reply to: wang890
    ok cool.
    but where in options? i've never see options have a thing for scale list default. i did'nt change anything that's set by civil 3d as default. i guess just don't reset scale then. problem solved.
    but still need to find this would be useful . let me know
    Civil 3D 2012
    Active Contributor
    gjcbachman
    09-19-2012 12:14 PM in reply to: wang890
    User Preferences/Default Scale List (lower right).
    Lisa
    Windows 7 x 64
    16 GB RAM
    NVIDIA Quadro 2000
    *Expert Elite*
    AllenJessup
    09-21-2012 01:20 PM in reply to: wang890
    Once you've got things the way you like them. A good way to make your customized list recoverable is to export the registry section where these values are stored. It will be in a path like
    HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.2\ACAD-A000:409\Scale List
    Export that section to a backup REG file. If things go pear shaped you can run this file and restore the values.
    As always - If you're uncomfortable working with the registry. Feel free to ignore this procedure.
    Allen
