• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    renumber sheets
    309 Views, 8 Replies
    01-02-2013 12:26 PM
    is there a way to renumber sheets in the sheet set manager? i've got over 100 sheets and i need to insert some new sheets in the middle. there wasn't a way in 2009 but i was hoping for something in 2012. it seems like something that would be included by now.
    Dell Studio XPS 9100
    Intel Core i7 CPU 930 @ 2.8GHz
    12GB Ram
    64 bit
    C3D 2012 SP2
    Please use plain text.
    DSM_dude
    Re: renumber sheets
    01-02-2013 01:42 PM in reply to: nostupidquestions
    It will not automatically renumber them, but you can go in sheet set manager and change the sheet numbers.
    Cad Blog:
    www.geaux-cad.blogspot.com
    Re: renumber sheets
    01-02-2013 01:46 PM in reply to: DSM_dude
    thanks for the reply. i guess i should have included a 'quickly' or 'automatically' in my post in regards to renumbering. renumbering each sheet takes forever.
    12GB Ram
    64 bit
    C3D 2012 SP2
    *Expert Elite*
    rkmcswain
    Re: renumber sheets
    01-02-2013 02:00 PM in reply to: nostupidquestions
    Nothing built in as you have seen (not sure why after all these years...)
    But given enough programming knowledge, it's certainly possible to roll up your own routine.
    We have such as tool and it pays for itself every time it is used.
    *Expert Elite*
    Re: renumber sheets
    01-02-2013 02:02 PM in reply to: rkmcswain
    How does this work if you have sheets numbered:
    01
    02
    03-A
    03-B
    04
    05
    Or do you just avoid this type of numbering?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Re: renumber sheets
    01-02-2013 02:17 PM in reply to: rkmcswain
    i got one somewhere several years ago but it doesn't work with 2012.  i agree that this feature should be included.
    12GB Ram
    64 bit
    C3D 2012 SP2
    *Expert Elite*
    Re: renumber sheets
    01-02-2013 02:36 PM in reply to: nostupidquestions
    There's also some 3rd party help if it's something you need.
    *Expert Elite*
    Joe-Bouza
    Re: renumber sheets
    01-02-2013 05:02 PM in reply to: troma
    Nothing against SincPac, my favorite is SSMproperetieseditor at JTBworl dot com
    and it more than renumbering
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    rkmcswain
    Re: renumber sheets
    01-03-2013 05:08 AM in reply to: troma
    01
    02
    03-A
    03-B
    04
    05
    Our numbering is usually very simple (1, 2, 3, 4, etc) - so our routine simply starts with the first sheet (1) and then numbers the rest sequentially. It also updates a custom property with the total number of sheets since we have a field that references that.
