• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Accepted Solution
    "No compatible objects found" looped dialogue when delete empty pipe network
    145 Views, 6 Replies
    07-23-2012 11:32 AM
    We have our pipe networks set up in our template.  But in actual use, we don't use them in every project.  Even in a project where we're using them, they will be d-ref'd around, so I don't need the actual network set up in each drawing.
    I was deleting my unused, empty pipe networks from a drawing (to reduce file size and to avoid getting the "8 Objects not selected" dialogue when using quick select.)
    I deleted 3 or 4 networks, then on the next one I got this message:
    C3D was apparantly not content with merely informing me once of this interesting fact.  No, the message was obviously considered so important that it had to be repeated.  Many many times, for emphasis.  So many times, that after I'd keept my finger on the Escape key for a minute or two, the program still felt that I needed to see this important dialogue box.
    I used Task Manager to get out of the program.
    Anyone got any suggestions?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    *Expert Elite*
    Re: "No compatible objects found" looped dialogue when delete empty pi
    08-17-2012 07:11 AM in reply to: troma
    Seriously, anyone at all?  No need to feel shy.
    *Expert Elite*
    08-17-2012 07:40 AM in reply to: troma
    Just so you dont feel ignored...I have never seen this, but then, I only used 2011 for a short time before going back to 2010 until 2012 was released. I, too, keep empty networks in my template and have deleted them when not needed without issue.
    Jeff_M, also a frequent Swamper
    *Expert Elite*
    08-17-2012 08:05 AM in reply to: Jeff_M
    Thanks.
    My workaround is to hit save after every second or third one is deleted.  Logically, if I crash after I just hit save I haven't lost much.  But I also feel like hitting save prevents crashes, as if it makes the program more stable if there's been a save recently.  Is that true, or just my imagination?
    *Expert Elite*
    08-17-2012 08:11 AM in reply to: troma
    If this works for you, then it must be true. :smileyhappy: Personally, I haven't noticed a difference whether I save, or not. The biggest difference, in the reduction of crashes, I've ever noticed was when I moved from a 32 bit OS and 4 gb RAM to a 64 bit system with 12gb.
    *Expert Elite*
    08-17-2012 08:15 AM in reply to: Jeff_M
    Must be nice   :smileysad:
    *Expert Elite*
    01-18-2013 08:19 AM in reply to: troma
    I think I just solved the mystery, somewhat at least.  I just did it again, but I realised that instead of clicking on "Delete" I clicked on "Export to Storm Sewers" just above.  Since there are no objects to export, the dialogue message makes sense, once.  Doesn't make so much sense ad infinitum.
    Anyone care to test this for me?  Close any other drawings, start a new drawing and make a pipe network with no pipes or structures.  Then right-click on the network and Export to Storm Sewers.  If I'm right, you will then need to Ctrl+Alt+Delete to close the program.  (I'm working in 2011)
