AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: "Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at 0h
- Highlight
- Email to a Friend
- Report Inappropriate Content
Dwayne,
If you sumbit a crash report via the CER window and post the email address you used, I can look up the crash to see what may be happening.
Here's a link to Civil 3D support options.
Autodesk, Inc
- Highlight
- Email to a Friend
FYI - jkonley provided more information offline. The crash issue with AutoCAD LT has been looked at and it seems to be a problem with 3rd party drivers (DisplayLink USB Graphics Technology), and an upgrade of those drivers has been known to resolve problems with AutoCAD by other customers who have reported such crashes.
Autodesk, Inc
- Highlight
- Email to a Friend
Solved. Thanks for the help. I had to update the driver for my NVIDIA video card and then in the new NVIDIA control panel, under global settings, set AutoCAD to always use the high performance NVIDIA video card. It was set to Auto Select. This got AutoCAD able to start and has been running with no problems since.
- Highlight
- Email to a Friend
Thanks for the confirmation, Jason. Appreciate the follow-up.
Autodesk, Inc
- Highlight
- Email to a Friend
I have the similar problem I have read and tried all the above..but the fatal error persists
please read a more detailed description of my problem here:
I have just installed Autocad LT 2013 (licence bought yesterday) on a new Lenovo E330 laptop and the first time I'm trying to run Autocad I'm getting the following error: "fatal error: unhandled Access violation writing 0x0000 exception at 0h".
I have googled a bit around and the most helpful link was the following:
I have tried the suggestions on the above posted link:
1. regediting the DWORD Low to all 0000000, but it goes back to whetever value it was (i have tried with changing value and restarting, not restarting... etc. numerous combinations) and the error is still there
2. On one ocasion an autodesk employees on that thread informed the user that the generated error report was pointing towards a usb display adapter, and as I was using an external replicator (USB) I decided to try with the laptop running by itself on it's own graphics, that didn't change the error message. Next step update the HD4000 driver to the latest from intel, but still the same fatal error.
On top of the above i have also completly unistalled Autocad and all related products, performed new installation with same fatal error again after the installation. I have tried different comatibility modes when running the software and i have tried running as administrator (although I am logged as administrator anyway)
ohh and not to forget I have already aplied the service pack before trying any of the above! and submited numerous error reports that autocad generated.
any help would be apreciated... "
- Highlight
- Email to a Friend
My main problem was that my Lenovo Thinkpad was factory set to use the Intel integrated graphics processor instead of my nvidia GPU. I had to change the default GPU processor to the nvidia and then AutoCAD worked with no problems.
- Highlight
- Email to a Friend
can you give me some steps on how to you set that? I don't have an NVIDIA external card (I have a Lenovo replicator that I don't have info on the grpahics unit) but a general guide on how to change between the Intel inside to the external...
also right now I will be happy if it starts running on the Intel one!
thank you very much
- Highlight
- Email to a Friend
I did not get it running on the onboard Intel integrated GPU. My laptop has a separate graphics card so I changed it to run on that. If you only have the onboard Intel graphics, I would check your driver and your settings to see if there is a better setup. I would not use your external monitor / port replicator until you can get it to run on your laptop screen.
- Highlight
- Email to a Friend
Did you update the graphics drivers for your USB graphics device?
Autodesk, Inc
- Highlight
- Email to a Friend
Yes I tried but I didn't find some newer software, I did though find a newer version of the intel HD4000 driver an updated it. So as I said i tried running it on the laptop itself without use or relpicator also but the error is still there.
