• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Accepted Solution
    "Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at 0h""
    6199 Views, 21 Replies
    08-28-2012 10:31 AM
    I get the above error when I attempt to open Civil 3d 2013
    Please use plain text.
    *Expert Elite*
    antoniovinci
    Re: "Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at 0h
    08-28-2012 10:42 AM in reply to: dwaynesmith
    We're with ya in this sad moment, D.S.
    If you have one, call your Autodesk dealer...
    Valued Mentor
    owenmull
    08-28-2012 01:42 PM in reply to: antoniovinci
    Scroll down in the forum a few posts, I posted a link to solve this issue on a previous thread.
    -Owen
    Windows 7 x 64 bit
    ATI FirePro V4800 Triple Monitor
    12 GB RAM
    Intel Xeon W3550 @ 3.07 GHz
    Civil 3D 2012 SP 2
    ______________________________________________________________
    Intel inside. Idiot outside.
    Usually, I find that the problem is between the keyboard and the chair.
    Member
    08-28-2012 02:24 PM in reply to: dwaynesmith
    I'm sorry, I can't seem to find the post you referenced.  Can you possibly add the link to this thread?
    Dwayne
    Valued Mentor
    owenmull
    08-28-2012 02:39 PM in reply to: dwaynesmith
    http://forums.autodesk.com/t5/AutoCAD-2010/FATAL-ERROR-Unhandled-e06d7363h-Exception-at-7c812afbh/m-...
    Read post # 8 in particular.
    -Owen
    Windows 7 x 64 bit
    12 GB RAM
    Civil 3D 2012 SP 2
    Member
    08-28-2012 03:34 PM in reply to: dwaynesmith
    I have changed the DWORD Low to all 0000000, but for some reason when I go to open the program, it changes it back to numbers and letters.  I have tried rebooting the computer, but that doesn't solve the problem either.  Any Help?
    Valued Mentor
    owenmull
    08-29-2012 06:48 AM in reply to: dwaynesmith
    Interesting. I've not seen it do that before. I'm sure someone else has a solution to this. Have you tried contacting Autodesk?
    -Owen
    Windows 7 x 64 bit
    12 GB RAM
    Civil 3D 2012 SP 2
    Member
    08-29-2012 07:10 AM in reply to: dwaynesmith
    I have looked for a way to contact Autodesk, but have not found a method to contact them.  I originally downloaded the program as a trial to see how it works, I have used other Autocad Versions.  This is not making me want to purchase the program.
    New Member
    11-05-2012 12:46 PM in reply to: dwaynesmith
    I also have a fresh install of AutoCAD LT 2013 64bit on Windows 7 Ultimate 64bit. and get this error. I tried the suggested fix and it did not help.  AutoDesk has been useless at providing and support resources, can anyone help?
    Member
    12-03-2012 06:16 AM in reply to: dwaynesmith
    Any update on this error?  I have a fresh install of AutoCAD LT 2012 on a Win 7 64 bit machine and have the exact same error.  I can't get the software to run for the first time yet.  Tried uninstalling and reinstalling, tried installing the service pack.  No luck.
