• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    "Copy dependent deleted objects" does not work or maybe I dont understand it...
    94 Views, 3 Replies
    03-20-2013 04:27 AM
    I have a closed polyline, I add it as a boundary , I delete it, I rebuild the surface (because I have the warning icon).
    Ok, the boundary line does not exist...  and I have the "standard" limits.
    What is for this option ????
    Any help would be appreciated.
    Please use plain text.
    *Expert Elite*
    Re: "Copy dependent deleted objects" does not work or maybe I dont und
    03-20-2013 06:04 AM in reply to: tonnot
    Do you set that option to Yes and Rebuild prior to deleting the boundary? The Surface should not be marked out of date when that is set to Yes and an object is deleted.
    VIDEO showing the process.
    Jeff_M, also a frequent Swamper
    *Pro
    03-20-2013 06:17 AM in reply to: tonnot
    copied from the help file....
    Insert contour data into the drawing as AutoCAD polylines using the Insert to Drawing command.
    In some situations, the surface keeps breakline or contour data (a list of their point coordinates), but does not associate them with an object. This may happen, for example, when you deleted an entity that the surface depends on, but the Copy Deleted Dependent Objects option on the Definition Tab (Surface Properties Dialog Box) page of the Surface Properties dialog box is set to Yes. In this case, the surface simply converts its reference from a drawing entity to a list of points defining the object’s geometry.
    To restore the reference to the object entity, you can insert the data associated with the deleted contour.
    cheers!
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    03-20-2013 09:25 AM in reply to: Jeff_M
    Ok, you have to mark the option before -
