• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    profile line visibility
    165 Views, 10 Replies
    12-10-2012 12:40 PM
    i'm doing a road project. i've got profile grades of existing left and right ditches. in some sections we're redoing the ditches so i've got proposed left and right ditch profiles. what i want to show is where i've got proposed ditch grades, i don't want to show existing ditch grades. the new ditches happen intermittently on the road so i would need to be able to turn off the existing ditches at various places. is this possible without exploding my existing ditch grades? thanks.
    Dell Studio XPS 9100
    Intel Core i7 CPU 930 @ 2.8GHz
    12GB Ram
    64 bit
    C3D 2012 SP2
    Please use plain text.
    *Expert Elite*
    Re: profile line visibility
    12-10-2012 12:43 PM in reply to: nostupidquestions
    If the existing ditch profile is from the surface, you can add hide boundaries to the surface.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    12-10-2012 01:26 PM in reply to: troma
    that's an interesting idea. would that not also mess with my cross sections? i need to show the existing grade in my sections. for the profiles, it's just too much linework to show existing and proposed. thanks for the idea though.
    12GB Ram
    64 bit
    C3D 2012 SP2
    *Expert Elite*
    BrianHailey
    12-10-2012 01:38 PM in reply to: nostupidquestions
    Create a new surface and paste in your finished ground surface. Add a hide boundary around the entire thing and then add show boundaries around the area you want to see profile for. Create a surface profile for that surface. If you turn Automatic Rebuild on, when you change the finished ground surface, this surface will update too. You can then assign a style to that surface that doesn't display anything (aka No Display) or put it on a layer and freeze it.
    12-10-2012 01:54 PM in reply to: nostupidquestions
    so basically there's no way to turn off the profile at selected stations without a lot of workarounds?
    12GB Ram
    64 bit
    C3D 2012 SP2
    *Expert Elite*
    BrianHailey
    12-10-2012 02:00 PM in reply to: nostupidquestions
    Correct. Alignment have the ability to mask between specific stations but currently profiles do not.
    Another option is to create multiple profiles with the desired station range for each one. The draw back to this is you can't change the start or end station of a surface profile once it's created (at least not that I'm aware of).
    *Expert Elite*
    sboon
    12-10-2012 02:10 PM in reply to: BrianHailey
    Another possilbe solution is to specify the station range for the ditch surface profile when you create each one.  Note - you cannot change the stationing after the profile is created.
    Third possible solution - rather than creating a surface profile you can extract the ditch featurelines from the corridor and then project them to your profile view.  You'll have to label them manually but they can be dynamic to the corridor if you're still working on the design.
    *Expert Elite*
    12-11-2012 05:47 AM in reply to: nostupidquestions
    Turning off the profile at selected stations has been on my wish list for years.  With a design profile you have even less options.
    12-11-2012 05:51 AM in reply to: nostupidquestions
    normally i would just explode the lines and trim it, which is what i'll end up doing here, but the road is 5 miles long and we are still in the early stages of design work so the less i have to recreate and redraw the better. thanks for the help though.
    12GB Ram
    64 bit
    C3D 2012 SP2
    Valued Mentor
    LisaPohlmeyer
    12-11-2012 06:28 AM in reply to: nostupidquestions
    SincPac from Quux software has a tool that will do exactly what you're looking for, I'm pretty sure. I've attached a pdf of a portion of the help file that describes the command. I use this add-on application for almost every project, there's always a tool that's not included in C3D, but it's in SincPac. Shameless plug, very reasonably priced. We have a combination of the full seat for our surveyor and the drafting modules for our designers. You can find it online here: http://www.quuxsoft.com/ My workflow would be to offset the alignment, then offset the polyline back. Use that 2d polyline to create the profiles at the station ranges you want.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
