• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    alex
    pipe and structures will not plot if publish sheets.
    115 Views, 2 Replies
    02-15-2013 05:46 AM
    if i plot a ps sheet (2012) indiviually the plan view pipes and structures and labels show up ok.
    but if i select 2 tabs or plot from sheet set manager the pipes do not show up but all the pipe labels do.
    i have read here that promoting the network may solve this problem but i only want to do that as a last resort.
    if there is something else to try that may solve this problem i would appreciate it.
    thanks, alex
    Please use plain text.
    Re: pipe and structures will not plot if publish sheets.
    02-15-2013 04:06 PM in reply to: alex
    Do you get the same results to different printers, ie hardcopy vs. PDF vs. DWF?
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Contributor
    alex
    02-16-2013 03:45 AM in reply to: tcorey
    they would not show up in either but later in the day i had to change some pipe sizes in the source dwg and they magically started printing.
