By mistake I used a metric unit of measure in a couple pay item files and english is a couple other. The model space unit is english (imperial) and I have a spreadsheet bill of material in metric. Initially, the payitems were in english units to match the model space unit and I converted the unit in the bill of material. There was some rework and missing items so after working in metric I created a couple short payItem lists but absentmindedly used a metric unit of measure. Is this a problem? Does Civil 3D convert if a metric unit of measure is used?
so I tested a pay item file with m2, sy, and sf and this is what I found:
What?
I did another test: With a flat roadway section that is easy to check with a hand calc, I used the analyze inquiry area tool and a payItem file with m2, sy, and sf. The result:
For the roadway section everything checks out
