AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
parcel settings not plotting correctly in 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I either have bad settings or have found a bug in 2012 when plotting parcels.
I have a P-drain Parcel setting for major drainage areas - I set the display to the C-PROP-BNDY layer which seems to be OOB for the entire 'property'. I create the parcels from poly lines on the P-DRAIN-AREA layer.
The parcels go to the C-PROP layer. My problem is that I can't seem to get the property lines to plot. I try to set C-PROP-BNDY to the correct color, yet when I plot, the lines don't show. C-PROP is on.
Re: parcel settings not plotting correctly in 2012
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Are there any non-plottable layers in the drawing?
Are the parcel lines turned on in model and plan in the parcel line style?
Does this happen if you pull up the drawing on another computer?
Can you post a sample drawing with just a simple rectangular parcel using the same parcel style?
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
6Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
