• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    parcel settings not plotting correctly in 2012
    81 Views, 1 Replies
    12-31-2012 01:50 PM
    I either have bad settings or have found a bug in 2012 when plotting parcels.
    I have a P-drain Parcel setting for major drainage areas - I set the display to the C-PROP-BNDY layer which seems to be OOB for the entire 'property'.  I create the parcels from poly lines on the P-DRAIN-AREA layer.
    The parcels go to the C-PROP layer.  My problem is that I can't seem to get the property lines to plot.  I try to set C-PROP-BNDY to the correct color, yet when I plot, the lines don't show.  C-PROP is on.
    Please use plain text.
    *Pro
    Re: parcel settings not plotting correctly in 2012
    01-02-2013 05:58 AM in reply to: annw2
    Are there any non-plottable layers in the drawing?
    Are the parcel lines turned on in model and plan in the parcel line style?
    Does this happen if you pull up the drawing on another computer?
    Can you post a sample drawing with just a simple rectangular parcel using the same parcel style?
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
