• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    merge surfaces
    8668 Views, 6 Replies
    04-16-2007 11:28 PM
    i have create a corridor surface for my alignment and now i want to merge my corridor surface with my platform surface... what are the steps
    Please use plain text.
    sboon
    Re: merge surfaces
    04-16-2007 11:33 PM in reply to: paorconsult
    - Create a new empty TIN surface
    - Expand the surface definition area in toolspace until you can see the surface edits.
    - Right click and select Paste Surface.
    - Select the EG surface
    - Repeat for the corridor surface. Your new surface will be a merge of the two.
    Active Member
    Re: merge surfaces
    04-17-2007 12:00 AM in reply to: paorconsult
    I noticed that the corridor surface that i create is not the surface by it own. it still in the corridor pack... is that mean i need to create another surfaces just for the alignment n coridor???
    BrianHailey
    Re: merge surfaces
    04-17-2007 03:58 AM in reply to: paorconsult
    What is up with the duplicate posts lately and why do I seem to always reply to the one that has no discussion on it?
    Brian
    p.s. This is not directed to you, paorconsult. It just seems to have happened to me a lot lately
    sboon
    Re: merge surfaces
    04-17-2007 12:16 PM in reply to: paorconsult
    The surface created by the corridor exists as a separate object, but all of the definition data is part of the corridor properties. When you rebuild the corridor, the surface automatically updates.
    You can use the surface just like you would any other, including a paste operation into a larger surface - or you can detatch it from the corridor and it will become a static object.
    New Member
    Forum_new
    Re: merge surfaces
    02-09-2011 01:19 AM in reply to: sboon
    I think I have similar kind of issue in my mechanical 3d model. Please find attached immage for explaination of problem faced.
    I would be thankful if someone can help me out.
    New Member
    felang
    Re: merge surfaces
    08-25-2011 07:18 AM in reply to: sboon
    Once the merge has been made I notice any changes you have made to the “Point Label Styles” are reset; is there any way to keep the changes made to the label styles after the merging of the two surfaces?
