AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
line weight in paper space
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We have a few drawings where the lineweights between paper space and model space vary on plots.
ie a line on Layer 1 in model space plots heavier/darker than a line on Layer 1 in paper space.
Why is this happening?
Re: line weight in paper space
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can think of two possible causes:
- You have a layer override in your paperspace viewport.
- You have different Plot Style tables assigned.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No overrides.
In the layer properties, everything matches between paper and vp settings. Unless there is another setting somewhere I have not noticed? (please let the answer be this simple)
This has happened in the past on acad and ldd programs so its not limited to C3d. Not all drawings do this, but some. Makes me think it is a drawing setting somewhere.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
HI Isimms,
What happens if you change plot scale. Does the lineweight changes? If it does, then check your Plot dialog and the "scale lieweight" toggle setting.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Please click on "Accept as Solution" if post helped you resolve the issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Not that either.
Keep the guesses coming. Sooner or later there will be the right one.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Did you ever figure out what was causing your issue? I have the same thing going on in my drawing.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry, no answer for you.
It may be a plotter setting issue. (?)
Lately I have been plotting to pdf, not a plt file or direct plot. Have not had it happen since.
