• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    line weight in paper space
    991 Views, 6 Replies
    04-28-2011 12:37 PM
    We have a few drawings where the lineweights between paper space and model space vary on plots.
    ie a line on Layer 1 in model space plots heavier/darker than a line on Layer 1 in paper space.
    Why is this happening?
    Please use plain text.
    *Expert Elite*
    Re: line weight in paper space
    04-28-2011 12:51 PM in reply to: lsimms1
    I can think of two possible causes:
    1. You have a layer override in your paperspace viewport.
    2. You have different Plot Style tables assigned.
    Sinc
    04-28-2011 01:14 PM in reply to: Sinc
    No overrides.
    In the layer properties, everything matches between paper and vp settings.  Unless there is another setting somewhere I have not noticed?  (please let the answer be this simple)
    This has happened in the past on acad and ldd programs so its not limited to C3d.  Not all drawings do this, but some.  Makes me think it is a drawing setting somewhere.
    Product Support
    AlmasSuljevic
    04-29-2011 06:09 AM in reply to: lsimms1
    HI Isimms,
    What happens if you change plot scale. Does the lineweight changes? If it does, then check your Plot dialog and the "scale lieweight" toggle setting.
    Almas Suljevic
    Product Support Specialist
    Autodesk Global Subscription and Support
    Autodesk, Inc.
    Please click on "Accept as Solution" if post helped you resolve the issue.
    05-02-2011 05:21 AM in reply to: lsimms1
    Not that either.
    Keep the guesses coming.  Sooner or later there will be the right one.
    New Member
    10-02-2012 11:50 AM in reply to: lsimms1
    Did you ever figure out what was causing your issue?  I have the same thing going on in my drawing.
    10-03-2012 05:29 AM in reply to: sslate
    Sorry, no answer for you.
    It may be a plotter setting issue. (?)
    Lately I have been plotting to pdf, not a plt file or direct plot.  Have not had it happen since.
