• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Accepted Solution
    lane slope, shoulder slope
    315 Views, 6 Replies
    11-07-2012 02:15 PM
    how can i get my shoulder slope to match my lane slope? there is a feature line with elevation that is following the end of my lane (off: 33.50'). but from there, i cant get my shoulder slope to match my lane slope. i cant set another profile for the 35.5' offset to follow and need this to work. see image, dont worry about the left side.
    thanks.
    Please use plain text.
    *Expert Elite*
    sboon
    Re: lane slope, shoulder slope
    11-07-2012 09:29 PM in reply to: MonkeyTrainer
    Use a parameter reference in your assembly.  This will allow the program to apply an output parameter from one sub as an input for another one.
    11-08-2012 08:01 AM in reply to: sboon
    you are using assemblies that i'm not using. i cant get the assemblies you used to do what i need. i have specific alignments and elevations i need to follow and that sub doesnt have the juice i need, sorry. is there possibly another method you or anyone else can think of to help me out, i am stuck here... thank you SBoon.
    *Expert Elite*
    sboon
    11-08-2012 08:05 AM in reply to: MonkeyTrainer
    Need more detail.  Post a sketch showing which subs you're using and how the assembly was built.  We'll also need to know which ones are being controlled by corridor targeting.  Can you post a drawing with the assembly in it?
    Employee
    11-08-2012 08:06 AM in reply to: MonkeyTrainer
    What shoulder SA are you using? They should all have that override built in to allow the lane slope to be passed to the shoulder.
    Peter Funk
    Autodesk, Inc.
    Peter Funk
    Autodesk, Inc.
    11-08-2012 08:23 AM in reply to: peterfunkautodesk
    right now i am using a "lanesuperelevationAOR" defined by a feature line and elevation, and a "shoulderextendsubbase". i also have a "linkoffsetandelevation" before the lane.  you can see it in the image on the original post. i thought i went through the definition of the shoulder looking for something like that, but if there is another one i need to use i gladly switch. thanks.
    11-08-2012 08:31 AM in reply to: MonkeyTrainer
    SUCCESS! ok, i found the option to have it follow the lane slope. thanks to everybody that posted!
