• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    install error
    39 Views, 1 Replies
    01-23-2004 11:04 AM
    Incorrect command line parameters?
    Can anyone help? Trying to install from the HD and not a CD.
    Thanks!
    Please use plain text.
    *Isaac Rodriguez
    Re: install error
    01-28-2004 06:46 AM in reply to: apweng
    Have you copied the entire CD image to your HD? Are you running the Setup.exe file at the root of the image? The error you are getting is usually shown by the Windows Installer service and installation is run from a script and the command line is incorrect. Are you launching the installation from a script? Thanks for reading. -- Isaac Rodriguez ================================ Software Engineer Autodesk, Inc. "apweng" wrote in message news:7029770.1074884728619.JavaMail.jive@jiveforum1.autodesk.com... > Incorrect command line parameters? > > Can anyone help? Trying to install from the HD and not a CD. > > Thanks!
