• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    basman12
    insert osm file
    561 Views, 5 Replies
    09-20-2012 01:55 AM
    Hello everybody
    how can i insert open street map file (osm) in autocad civil 3d 2012.
    thanks
    Please use plain text.
    antoniovinci
    Re: insert osm file
    09-20-2012 02:35 AM in reply to: basman12
    You can't directly, so open the .OSM file in Qgis, then "save as" DXF format.
    Valued Contributor
    basman12
    Re: insert osm file
    09-20-2012 03:24 AM in reply to: antoniovinci
    Thank u for your answer
    But how can i open it in qgis program i download it and i dont find anyway to open the .osm file.
    thanks
    antoniovinci
    Re: insert osm file
    09-20-2012 03:59 AM in reply to: basman12
    basman12 wrote:
    I dont find anyway to open the .osm file
    CTRL-SHIFT-V => BROWSE => OPEN
    Murph
    Re: insert osm file
    09-20-2012 03:56 PM in reply to: basman12
    Try connecting to it as WMs connection.
    Simply add a new WMS layer in Display Manager:
    Data > Connect to Data > Add WMS Connection
    1. Add http://wms.latlon.org/?layers=osm and version as 1.1.1
    2. Cick Connect
    3.  Click Login
    4.  Check OpenStreetMap mapnik
    5. Click Add to Map
    Murph
    Supportting the troops daily.
    Valued Mentor
    TerryDotson
    Re: insert osm file
    09-21-2012 09:21 AM in reply to: basman12
    If you were to consider third party add-ons, MapWorks Base will import .OSM files directly into Civil3D (or plain AutoCAD).  The files are in lat/long and are projected to a designed plane system assigned to the current drawing.
