• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    MKH-VB
    imported shape file and elevations
    657 Views, 19 Replies
    04-12-2012 07:27 AM
    I have an interesting problem.  I have imported a shp file from a state agency.  This file contains contours for an area.  When I tag the pline, it shows a "zero" elevation, but shows a numeric elevation within the DXF_ELEV feature.  Please see the attached image.  I am needing to convert these to pline with elevation to work on in autocad.  Can someone tell me how to get polyline w/ elevations to export from c3d?  Thanks for any help you can give.c3d elevations.png
    mkh
    Please use plain text.
    Distinguished Mentor
    thepworth
    Re: imported shape file and elevations
    04-12-2012 07:42 AM in reply to: MKH-VB
    See if you can follow using the import & change properties by drawing query - I put a document together & posted in the following thread:
    http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Object-information-to-object-geometry/td-p/3367841
    C3D 2011
    Intel Xeon E5630@2.53Ghz
    NVIDA Quadro NVS420 Dual Monitor
    12GB Ram / Win7 Professional 64bit SP1
    04-12-2012 08:13 AM in reply to: thepworth
    That query workflow is no longer required.  Civil 3D has a tool built in for that now.  Import Tab, Insert Panel.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    MKH-VB
    04-12-2012 08:16 AM in reply to: MKH-VB
    C3D 2011?
    mkh
    MKH-VB
    04-12-2012 08:27 AM in reply to: MKH-VB
    that document loses me at number 6 iv.  Have no idea what "e234_mowest" is.
    MKH
    mkh
    thepworth
    04-12-2012 08:32 AM in reply to: MKH-VB
    sorry, it was data specific for that user - I think I have the original document on my PC at home, but not sure.
    In general, the idea was to mapimport the gis data into a drawing & create object data.  The we were transforming from the drawing with the imported data (contours at 0 elevation) and using a "alter properties during drawing query" to force the contours to the correct elevation.
    I'm sitting in on a webinar today, so if you have specific questions, or want me to look at what you're wanting to do, I'll be happy to do what I can so I don't die of boredom here :smileyhappy:
    C3D 2011
    MKH-VB
    04-12-2012 08:35 AM in reply to: thepworth
    I am wanted polylines with elevations, so I can work on it in autocad. Is there a way for me to attach the cad file?
    mkh
    thepworth
    04-12-2012 08:53 AM in reply to: MKH-VB
    Create a new drawing & assign the coordinate system to match the .prj file from the shapefile.
    Mapimport & create object data.  Make sure the object data includes the elevation assigned to the line in the shp file (shape files are 2.5D - elevation is an attribute).
    then attach this drawing to your design/destination drawing in your design coordinate system. - from the "map explorer tab" of mapwspace, right click on drawings & follow the dialog to attach.
    then query the drawing and use "alter properties" to assign the object data of the elevation from the shp to the z values of the resulting polylines.
    detach the intermediate drawing & ignore the warning message.
    HTH
    C3D 2011
    MKH-VB
    04-12-2012 09:10 AM in reply to: thepworth
    awesome....that did it.  Thanks much.
    MKH
    mkh
    04-12-2012 11:35 AM in reply to: MKH-VB
    Not 2011, this is why it's important to include your version in every post you make.
    Matt Kolberg
