AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
import fbk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I created a fbk with trimble business center. The fbk is all coordinates. C3D 2012 implys this fbk is all control points.
Is there a way to import a fbk so that c3d reads the points as non-control points?
Is there a way to change the points attributes to non-control?
Is there a toggle in C3D so I can edit multiple points before regenerating the network?
Thanks.
Dell M6600, Core i7 @ 2.3GHz, 16 GB ram
Re: import fbk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Instead just import a ascii text file. Then it wont use the FBK stuff.
Re: import fbk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Edit the field book file and change the "NE" or "NEZ" commands to "NE SS".
Re: import fbk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We have and are looking at ascii files but the way c3d reads them with attrubutes has been giving us some problems. When are working on a stylesheet from TBC that will work with c3d. It is not very useful that civil 3d does not seems to allow attribute names to be imported via csv. It seems to only read values.
Our current csv line is similar to
Point,Northing,Easting,Elevation,Code Attribute Value Attribute Value... /Note
Has anyone gotten c3d to read a line similar to
Point,Northing,Easting,Elevation,Code,Note,Attribu
Re: import fbk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
C3D will not use the additional informatino natively, upon import with out the use of UDP's. Then things just seem to get a little convoluted. I guessing that this may be an equipment function/ collector function - that works well for the DC but is quite burdensome to get into C3D at the moment. Out of curiousity what equipment are you using?
Re: import fbk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We use Trimble collectors and with TBC we can export any format ascii using style sheets. I don't have a good gripe on how c3d can utilize attributes and notes but at this time it seems poor to me when it comes to importing them.
We are trying for the
but I don't think c3d will let us use the attribute name column.
What's a UDP?
Re: import fbk
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
UDP? User Defined Propeties
You may also what to look at Survey Extended Properties
This all depends on the Data your trying to Import.
