• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    image shifting in rotated viewport
    539 Views, 18 Replies
    09-05-2007 01:30 PM
    any ideas on what is happening
    i have an area we are running water lines in and are using the aerial as the survey kind of - so it is important that it not shift - but the viewport needs to be rotated
    thanks
    lgs
    Please use plain text.
    *Brian
    Re: image shifting in rotated viewport
    09-05-2007 01:54 PM in reply to: lgs663
    use the dview command and twist...... enter the angle you wish to rotate the
    view to
    you have to be in an unlocked viewport for this to work
    wrote in message news:5711651@discussion.autodesk.com...
    needs to be rotated
    thanks
    lgs
    10-23-2007 12:24 PM in reply to: lgs663
    I keep on getting the same problem.... DVIEW and TW, did not resolve the images problem....
    Has anyone found anyother workaround?
    TIA
    - Alberto
    10-23-2007 01:24 PM in reply to: lgs663
    dv twist did not solve my problem either
    and now i cannot even access my tabs when the aerial is loaded - which is putting me in a real pickle
    10-23-2007 01:29 PM in reply to: lgs663
    I just noticed something. The images I had were OLE objects (don't know why or how these images got here). I copied and converted those pics to JPEG, then I re-imported those JPEG images using the Map/Image/Insert, I brought them in, scaled them up and place them approx where they needed to be and that worked! Then when I rotated it, the image did not disturb.
    It seems that the OLE objects don't like to rotate.
    Hope that helps.
    - Alberto
    10-23-2007 01:36 PM in reply to: lgs663
    thanks
    now my problem is - my image is a sid - which i believe autocad does read as an OLE object - but sids do not convert to jpgs very well
    thanks
    10-23-2007 01:55 PM in reply to: lgs663
    If you get the Raster Design Object Enabler, you will be able to import the MrSid file through either MAPIINSERT or IMAGE. Below is a link to the Object Enabler for R2008.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9476871&linkID=9240698
    10-24-2007 12:42 PM in reply to: lgs663
    well, for SID images, use the MAP - IMAGE - INSERT and insert those SID images. Make sure you import those images directly in the drawing where the exhibit is being created (don't XREF in). That should work.
    - Alberto
    10-26-2007 01:03 PM in reply to: lgs663
    I've had this problem for a long time, even using map image insert. My files are ECW format, which is just like a SID file. I just have resigned myself to not using images twisted viewports. REALLY BUGS.
    10-26-2007 01:23 PM in reply to: lgs663
    Would you be able to post an example of a DWG/ECW pairing where this problem occurs?
