AutoCAD Civil 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
hyperlink cursor
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
74 Views, 3 Replies
04-12-2005 03:29 AM
Is possible to use hyperlink cursor with osnap to use do inquiry intersection of 2 alignments??
Is possible to control hyperlink cursor because when I have a lot of alignments the monitor area is insufficient to see all Station/Offset in hyperlink cursor cursor. Is possible to hyperlink cursor showing only the 2 last aligments that i am working??
Joao
Joao
Re: hyperlink cursor
Options
- Highlight
- Email to a Friend
04-13-2005 02:19 PM in reply to:
JoaoMM
Is possible to see station/offset of hyperlink cursor using osnap points??? I want to see a intersection of two alignments or end point of a curve. Is possible to use an "osnap" to see the exactly station and offset. I dont want to use Label to do this!!!
Joao
Joao
Options
- Highlight
- Email to a Friend
04-14-2005 01:28 PM in reply to:
JoaoMM
Very simple, but you must use the label command (without actually placing a label in your drawing) AND the "Magnet" option must be turned on for the AutoSnap settings (options dialogue, drafting tab).
1. From the pulldown menu: Alignments>Add Labels...
2. Click the "Add" button.
3. Select the alignment that you want the station and offset to reference.
4. Move your cursor near the point you want to snap to (make sure your osnap is set accordingly) and the cursor will magically move to point you wish to query. The station and offset are displayed near the cursor.
TIP: If your hands are very shaky just let go of the mouse after is "magnetizes" to the osnap point.
When done just right-click to end the command without placing a label.
HTH
HTH
ACADuser
Dell Precision T5500 Workstation
Windows XP Professional SP3
Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
16XDVD AND 16XDVD+/-RW
Options
- Highlight
- Email to a Friend
04-15-2005 06:58 AM in reply to:
JoaoMM
Thanks HTH!!! It helps me a lot!
Is possible to do something similiar but with my finnished ground in profile view.
Is any manner to list/ or to see in hyperlink cursor elevation of finnished ground in a specified station.???
Example:
I want to see the elevation on Km 0+554,513 of Finnished Ground of Road 2???
JoaoMM
Example:
JoaoMM
