• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    caddie99
    how to get to "cogo input dialog box" - I dont use the ribbon , using c3d2012 64
    110 Views, 2 Replies
    10-29-2012 04:33 PM
    I want to try the point inverse report but I am stumped on how to get
    to this dialog box?
    I type 'cogo' and get to a cogo traverse box but nothing shows up about inverse report.
    Is there a non-ribbon method?
    Im so green at the ribbon that I type "ribbon" but still cant find it
    Please use plain text.
    *Expert Elite*
    Re: how to get to "cogo input dialog box" - I dont use the ribbon , us
    10-29-2012 04:52 PM in reply to: caddie99
    You can use that COGO dialog to get the report you want.
    Easy way I have found is to draw a polyline through the points in the inverse. Snap to the nodes.
    Type COGO.
    Upper left is an icon for Load Traverse from Polyline. The inverse data will fill the bottom of the dialog.
    Back at the top, be sure it says No Adjustment in the Adjustment and Balance Rules pulldown. The next button to the right is Display Traverse Adjustment and Closure Reports. Because you selected No Adjustment, this will be an inverse of  your points.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Active Contributor
    caddie99
    10-30-2012 07:15 AM in reply to: tcorey
    Thanks,  but I need point numbers in my report to satisfy the County surveyor.
