Civil 3D Forum
how to edit station labels
3 REPLIES 3
ChrisHibbert
1821 Views, 3 Replies
I have two problems I can't seem to fix.
First - the alignment station label text size when viewed in model space is fine but when viewed in paper space it comes in way to big. How do i adjust this so i see things in paper space as they are in the model?
Second - Would like to adjust the station label style from the defalt 0+00.00 to 0+000.000
3 REPLIES 3
neilyj666
in reply to: ChrisHibbert
Set the scale in model space to the same as viewport then WYSIWYG.
The labels are in plotted units so (in metric units) 3mm label will be large at 1:2500 compared with 1:500
Can't remember the answer to point 2 so looking........
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
AllenJessup
For the text you need to set your drawing scale equal to your PS Viewport scale.
For the Station Display you need to change it in your Label Style:
Allen
Allen Jessup
CAD Manager - Designer
neilyj666
in reply to: neilyj666
Need to change style - see screenshot - remember to hit the Right Arrow in Text Component Editor - Contents dialog to transfer the style to the black area
Rail Community
