• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    nimadadgar57
    how to Define Vegetable soil Thickness when Calculating Earthwork Volumes
    268 Views, 3 Replies
    01-26-2012 05:49 AM
    when i want to Calculate Earthwork Volumes there are some factors :
    • The Cut factor is typically used as an expansion factor for excavated material. It is usually 1.0 or higher.
    • The Fill factor is typically used as a compaction factor for fill material. It is usually 1.0 or higher.
    • The Refill factor indicates what percentage of cut material can be reused as fill. It should be 1.0 or lower.
    but no one aren't use full for exactly Define the Vegetable soil Thickness in cut and fill, is there another way?
    C3D 2012,
    AMD phenom II 3.4GHZ 6 core CPU,
    16 GB RAM DDR5,
    60GB SSD + 1000GB HDD
    NVidia Quadro 4000 running driver version 276.14 without Performance driver
    Win 7 64-bit professional,
    Please use plain text.
    *Expert Elite*
    Re: how to Define Vegetable soil Thickness when Calculating Earthwork Volumes
    01-26-2012 09:56 AM in reply to: nimadadgar57
    If this is a constant value you could copy the og surface, raise it the thickness of the veg surface, and then use Volumes to compare the two surfaces.
    It's not a 'factor' but it makes it fast and easy to get the number.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Mentor
    01-26-2012 01:22 PM in reply to: nimadadgar57
    That's also how we do it. Paste the existing ground surface into a stripped surface and lower the stripped surface by 6 inches, or however much it needs to be. That way you get a rough volume on stripping  and you take the revised eg into account when filling back up again.
    *Expert Elite*
    neilyj
    01-27-2012 02:39 AM in reply to: KirkNoonan
    I use this approach:
    Input the organic soil thicknesses obtained from trial pits/boreholes etc etc into Civil 3D such that the Z value is the thickness in your local units e.g. 0.3m, 0.25m, 0.175m etc and call it e.g. SOIL THKS
    Create a volume surface (VOLSURF) with SOIL THKS as Base and EGL as Comparison surface to give a volume surface where the Z value is the level of the base of organic soil
    Create new Surface (BASE OF SOIL) and paste VOLSURF into it and now you have a normal TIN surface of Base of Soil to use as required. This surface remains dynamic so any new soil thickness info is automatically included.  This method assumes interpolated soil thicknesses between site investigation locations (which may not be a valid assumption) so additional dummy thicknesses may be needed as required.
    A similar technique can be used to create base of construction (i.e. earthworks formation) level surfaces knowing the finished levels and construction thicknesses e.g. heavy duty road, footpath, landscape area etc.
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014, Civil 3D 2013 (UKIE) Hotfix 3; Win 7 Pro x64
    256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
