AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
how to Define Vegetable soil Thickness when Calculatin g Earthwork Volumes
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
when i want to Calculate Earthwork Volumes there are some factors :
- The Cut factor is typically used as an expansion factor for excavated material. It is usually 1.0 or higher.
- The Fill factor is typically used as a compaction factor for fill material. It is usually 1.0 or higher.
- The Refill factor indicates what percentage of cut material can be reused as fill. It should be 1.0 or lower.
but no one aren't use full for exactly Define the Vegetable soil Thickness in cut and fill, is there another way?
C3D 2012,
AMD phenom II 3.4GHZ 6 core CPU,
16 GB RAM DDR5,
60GB SSD + 1000GB HDD
NVidia Quadro 4000 running driver version 276.14 without Performance driver
Win 7 64-bit professional,
Re: how to Define Vegetable soil Thickness when Calculatin g Earthwork Volumes
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If this is a constant value you could copy the og surface, raise it the thickness of the veg surface, and then use Volumes to compare the two surfaces.
It's not a 'factor' but it makes it fast and easy to get the number.
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
That's also how we do it. Paste the existing ground surface into a stripped surface and lower the stripped surface by 6 inches, or however much it needs to be. That way you get a rough volume on stripping and you take the revised eg into account when filling back up again.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I use this approach:
Input the organic soil thicknesses obtained from trial pits/boreholes etc etc into Civil 3D such that the Z value is the thickness in your local units e.g. 0.3m, 0.25m, 0.175m etc and call it e.g. SOIL THKS
Create a volume surface (VOLSURF) with SOIL THKS as Base and EGL as Comparison surface to give a volume surface where the Z value is the level of the base of organic soil
Create new Surface (BASE OF SOIL) and paste VOLSURF into it and now you have a normal TIN surface of Base of Soil to use as required. This surface remains dynamic so any new soil thickness info is automatically included. This method assumes interpolated soil thicknesses between site investigation locations (which may not be a valid assumption) so additional dummy thicknesses may be needed as required.
A similar technique can be used to create base of construction (i.e. earthworks formation) level surfaces knowing the finished levels and construction thicknesses e.g. heavy duty road, footpath, landscape area etc.
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
