• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    djocwf54
    how do you save customizations before loading hotfix
    68 Views, 1 Replies
    12-03-2012 06:35 AM
    I need to load a hotfix for my autocad civil 3d how do you do the following
    Before applying this update, make sure that any customizations made to the user profile (such as, customizations made to the support file search paths, print file customizations, printer support file paths, redirections, custom template settings, and so on) are exported to a secure location, then imported and reapplied after the update has been successfully installed.
    Please use plain text.
    *Expert Elite*
    Re: how do you save customizations before loading hotfix
    12-03-2012 07:37 AM in reply to: djocwf54
    I've never done this, but I think I know what it's reffering to.
    Go to Options>Profiles.  There you can select a profile and Export.  Export to somewhere & save.  There is also a button to import in here.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
