• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    basman12
    how can we reverse alignment direction ???
    874 Views, 3 Replies
    03-27-2011 12:23 PM
    Hello everybody
    is there is any way to reverse the alignment direction
    Please use plain text.
    Re: how can we reverse alignment direction ???
    03-27-2011 01:18 PM in reply to: basman12
    Select the alignment the ribbon will change and on the tab with alignment properties - Superelevation ect. hit the flyout and there you will find reverse alignment. Make sure you use the flyout not the drop down from alignment properties
    NVIDIA Quadro 600
    Civil3D 2012 64x
    01-22-2013 11:11 PM in reply to: basman12
    How does one "hit the flyout"?  I cannot find this command.  I'm using C3D 2012.
    01-23-2013 05:33 AM in reply to: Jozi68
    The flyout is the part that "flies out" when you hit the little arrow on the bottom of the ribbon.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
