• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Vic
    groundline shifting in profile upon opening drawing - 1 attachment
    115 Views, 9 Replies
    08-18-2009 02:42 PM
    Anyone seen any issues with the ground line shifting on your profile when
    you open a drawing? Several of us without our company have the issue, most
    times we can go into MS then back to PS and all if fine, but are starting
    to have issues with that workaround not fixing the problem. It appears to
    happen with only data referenced profiles.
    Please use plain text.
    *Himanshu Gohel
    Re: groundline shifting in profile upon opening drawing - 1 attachment
    08-19-2009 12:08 PM in reply to: *Vic
    Vic,
    Since you did not state the version of Civil 3D you are running I can't
    be sure this applies, but it sounds like it might. From the release
    notes for Update 1 for Civil 3D 2010:
    Shortcuts
    * Layout profiles based on data shortcuts in an AutoCAD Civil 3D
    2009 drawing no longer move to different locations when the drawing is
    opened in AutoCAD Civil 3D 2010.
    Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
    Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
    Civil Engineering Community Portal: http://civilcommunity.autodesk.com
    *Vic
    08-19-2009 01:14 PM in reply to: *Vic
    both 2009 and 2010. Both versions have all service packs. If you want a
    support ticket, I can get ya one, just email me kkempker at gmail
    *Himanshu Gohel
    08-19-2009 02:15 PM in reply to: *Vic
    want a
    You're in good hands with our support, so it should be fine.
    *Vic
    08-19-2009 02:31 PM in reply to: *Vic
    > want a
    They say they have never seen the problem before...
    *Himanshu Gohel
    08-20-2009 06:57 AM in reply to: *Vic
    This issue did not affect C3D 2009, so it should not happen in that
    version. BTW, "all service packs" isn't very descriptive - knowing the
    specific service pack you have installed is critical.
    For C3D 2010: if your drawing was migrated from 2009, open the 2009
    drawing again after you install Update 1 for C3D 2010 and you should not
    see the profiles shifting.
    *Vic
    08-20-2009 10:17 AM in reply to: *Vic
    Not true. I've used nothing but 2009 on this project and I see the
    ground line shifting every time I open the drawing. I have all service
    packs for C3D 09 installed, Help > About says "version 4"
    I have SP1 for 2010 installed, still have the issue. I'm not the only
    one in our company that has the problem.
    not
    *Himanshu Gohel
    08-20-2009 10:51 AM in reply to: *Vic
    To be clear:
    >> version.
    When I said that, "this issue" referred to the issue fixed with Update 1
    of C3D 2010. If you are experiencing an issue in C3D 2009, that may not
    be the same problem. I'm not disputing the fact that you may be
    experiencing the problem that you describe.
    As far as the issue occurring in 2010, I am still not sure whether you
    migrated the drawing from 2009. If you did, you must reopen the
    original drawing in 2010 *after* the update has been applied to see the
    issue resolved.
    *Himanshu Gohel
    08-20-2009 10:54 AM in reply to: *Vic
    > service packs for C3D 09 installed, Help > About says "version 4"
    > only one in our company that has the problem.
    To be clear, when I wrote this:
    >> version.
    of C3D 2010.
    experiencing the problem that you describe. Please continue to work
    with support and provide them with all the drawings that exhibit this
    behavior.
    *Vic
    08-20-2009 11:15 AM in reply to: *Vic
    > issue resolved.
    I have and continue to have the problem.
